Auto Max AC Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dano.oh, Dec 19, 2013.
  1. Jul 24, 2018 at 8:38 PM
    #81
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Easily located and replaced?
  2. Jul 25, 2018 at 6:47 AM
    #82
    Taco'09
    Taco'09 Well-Known Member
  3. Jul 25, 2018 at 7:03 AM
    #83
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
  4. Jul 25, 2018 at 5:08 PM
    #84
    Taco'09
    If this were mine I would look first at the air inlet servo. Its the one that controls recirculation.
    You can also "listen" to the servos. There are three servo motors: the mode control, the temp control, and the air inlet/recirculation control servo. The first two are located on the right side of the HVAC box (right side as viewed sitting in the pass seat), and the last is on the inlet just below the grill but inside the cabin. This last one is on the left side of the air inlet as you would sit in the pass seat but you have to reach high up, above the cabin filter, and removing the glove box helps.
    For a normally operating system, with the key turned on but the engine not started turning the mode control knob (air at face >> defrost >> and then back) you should hear that servo run and flaps inside the HVAC box move. Now try the temp control knob and rotate from cold >> hot, you should hear the servo motor run and may hear the flap door inside the HVAC box move. Finally, for the air inlet/recirc servo you should be able to push the red button, have it light, and hear its motor and flap.
    I noticed from an earlier post that you may have modded the wiring some. Never hurts to check that one.
  5. Jul 25, 2018 at 11:33 PM
    #85
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Thanks for the info & tips. Yes, I did the auto Max AC mod some time ago. The recirc has been working fine when the button was pushed, until just recently, when I noticed nothing changed when I pushed the recirc on button. I'm going to check the wiring this weekend. I thought about taking it in to the dealer, as I have an extended warranty, but 1) they might find the mod and say they won't work on it since it's been modified, and 2) I'd rather just fix it myself if I can find the problem.
  6. Jul 26, 2018 at 12:00 AM
    #86
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    Subd
  7. Jul 28, 2018 at 12:21 PM
    #87
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Went into the area behind the glove box today to check out the recirc issue. First thing I noticed right away was the door on the cabin air filter compartment was not shut, probably left open by the last guy who replaced the CAF at the dealership (I know, I know). I could see that the filter looked exceptionally dirty, so I pulled it out. It was full of crap. Our neighbor has horses, and he refuses to clean up after them, just rake it around with a tractor. So when the wind blows, it all comes our way. So the filter was pretty clogged up with horse crap powder. Took that out, cleaned it up, blew it out with compressed air, and put it all back in. Guess what? I can now tell the difference when I turn on the recirc button. The combination of the clogged filter and the filter compartment door open seems to have affected the air flow, to where I could not tell that the recirc was working. It seems to be fine now.
