Auto or manual for towing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaTaco04, Mar 30, 2020.
  1. Feb 2, 2022 at 10:18 PM
    Glamisman
    Glamisman Well-Known Member
    throw some sandbags in the bed… more traction from the weight and some grit to put on the mossy ramp.
  2. Feb 2, 2022 at 10:31 PM
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    Manual seems more reliable but auto is more pleasurable to deal with in my experience.
  3. Feb 3, 2022 at 2:54 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Tundra.
  4. Feb 3, 2022 at 4:42 AM
    NSDON
    NSDON Well-Known Member
    Don
    NS
    02 SR5 TRD 4X4 Step Side
    When towing I only use od on the flats or downhill. The Tacoma’s torque curve and gearing puts a lot of load/stress on the clutch on hills. Having oversized diameter tires puts more load/stress on the clutch as well. Same goes for an automatic, keep it out of od under load.
    To avoid burning up your clutch on a boat ramp, I use 4wd low, the reduced gearing lets you get the clutch pedal all the way out faster and with less riding of the clutch. I also use low 4wd when backing into tight spots with the trailer, it’s easier to maneuver at slower speeds.
