Auto start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trail and error, Mar 17, 2020.
  1. Mar 27, 2020 at 10:56 PM
    #41
    DR TACO
    DR TACO Well-Known Member
    Denny
    Fort Mohave
    2019 Tacoma Off Road 4x4 Double Cab
    Pro grille, POD lights, SEMA wheels.
    Perfect, Thank you! So, it’s the external key fob system that can’t be used in conjunction with the smartphone application.
  2. Mar 28, 2020 at 4:01 AM
    #42
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Your key fob will work just as if you didn't have the smartphone app. The app is in addition to you key fob. So you can lock/unlock the truck with your fob or app. You can remote start by hitting the lock on your fob 3 times or you can use the app to remote start.
    Gvsukids likes this.
  3. Mar 29, 2020 at 12:37 AM
    #43
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    If you mean external keyfob being the OEM fob, then incorrect. The OEM fob IS how our kits start and stop the engine. You press lock 3 times on you OEM fob to start the engine, 3 more times to stop it. Your OEM fob IS what works in conjunction with the smart module add-on. The remote start kit (which you must have before you add a smart module) works using your OEM fob. We don't give you, nor do you need any extra fobs for this system (unless you have a base model SR that didn't give you OEM fobs from the dealership, then we'll provide it in that kit). There are two parts to the setup, the remote starter module and then if you so desire, the optional add-on, being the smart module. Which can be added at anytime down the road if it's not purchased t the same time. However, most folks (8 out of 10 - we ran the reports) come back for the smart module IF they didn't add it to their cart the first time. So if not budget prohibited, some folks just bang it all out at the same time since the trim is already open.
  4. Mar 29, 2020 at 6:16 AM
    #44
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Smart phone app is totally worth it...
    The oem key fob range is not great, and now I can't imagine having to get that close to start my truck.
    With the app I start it while at work, while inside shopping at the mall, at kids ball games.
    Oh, and someone calls and needs something out of the truck, sure hold on, let me unlock it from my phone!
    N2DesignsInc, Gvsukids and DSRamsey13 like this.
  5. Mar 29, 2020 at 10:44 AM
    #45
    N2DesignsInc
    Los Angeles, CA
    Just so others are aware...the range is whatever your fob was before the remote start as we neither increase or decrease range. System is only looking for 3 pulses of the OEM fob lock function. I know you already know this @DTaco18 but more of a PSA for folks not aware. But as you mentioned, we can do things to increase range easily from up to a half mile via Long Range RF fob add-on to worldwide via smart phone module add-on.
  6. Mar 29, 2020 at 10:47 AM
    #46
    N2DesignsInc
    Los Angeles, CA
    ...to the front yard and back...:rofl:
    DSRamsey13[QUOTED] likes this.
  7. Mar 29, 2020 at 11:19 AM
    #47
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    I installed 12 Volt Solutions Remote Start with Smartphone module and app. It works great and the phone app also has GPS truck loction. It's all plug and play. No wire cutting or splicing.
    https://www.12volt.solutions/
  8. Mar 29, 2020 at 11:20 AM
    #48
    N2DesignsInc
    Los Angeles, CA
    Same hardware, different mark up ;)
  9. Mar 29, 2020 at 11:23 AM
    #49
    Scott W
    Scott
    Saranac Lake, NY
    Pretty much one company manufacturers these remote start kits and sells them to middle-man companys. They put there name on them.
    N2DesignsInc[QUOTED] likes this.
  10. Mar 29, 2020 at 1:00 PM
    #50
    DR TACO
    Denny
    Fort Mohave
    Yes, I understood that. Sorry for the confusion, I overthought it.
