Auto to manual swap progress
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfcarpenter, Feb 11, 2023.
  1. Feb 13, 2023 at 10:26 AM
    cfcarpenter
    cfcarpenter [OP] Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    Ok great thanks for the info ill grab this one. I think all I will have to do to install it and attempt hope that this process will allow it to start/run [​IMG]
  2. Feb 13, 2023 at 10:28 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What are you gona do about wiring? The harnesses are different from auto to manual.
  3. Feb 13, 2023 at 10:41 AM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
  4. Feb 13, 2023 at 10:49 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea it's mainly the reverse switch, clutch safety, and clutch cruise switches, the speedometer works differently on auto and manual but since your going from auto to manual it should still work with no modifications.
  5. Feb 13, 2023 at 10:58 AM
    SparkyIX
    SparkyIX Well-Known Member
    Anthony
    Tonopah, AZ
    2009 TM 4x4 DCSB 6-Speed Swap
    Mine is from a access cab MT
  6. Feb 13, 2023 at 11:02 AM
    SparkyIX
    Anthony
    Tonopah, AZ
    Here’s what I was sent from @JustDSM. This was to program the immobilizer to the M/T computer.
  7. Feb 13, 2023 at 11:05 AM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Ok, thanks for the info SparkyIX. I was following along on your swap. Ill grab this ECU and give that process a shot when I get to that point, I dont think I will have to have the Vin re-wrote if do that process.
  8. Feb 13, 2023 at 11:06 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yep that's it, ideally you should get the correct VIN written to the PCM as well but it isn't a necessity.
  9. Feb 13, 2023 at 11:07 AM
    SparkyIX
    Anthony
    Tonopah, AZ
    He also added my vin to make it more legit.
  10. Feb 13, 2023 at 11:08 AM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Hopefully its fairly simple, wiring is my weakness. Clutch was delivered today hopefully I can start pulling the auto tonight.
  11. Feb 13, 2023 at 11:11 AM
    SparkyIX
    Anthony
    Tonopah, AZ
    I tapped the yellow IGN wire on the NSS -> to the reverse switch on m/t trans -> then output of reverse switch to the red wire on NSS. You may have a hidden connection around down there. I’d check when you pull the trans.
  12. Feb 13, 2023 at 1:16 PM
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    OK thanks ill take a look around, would be sweet if there was. Only other issue I see popping up is the line to the slave cylinder. I have most of the original stuff from the truck the transmission came out of. Only issue is they mangled it all up. I have the brackets and soft line along with the accumulator (not planning to install that). I found some part diagrams but they show multiple parts under that same diagram number. I either need to go in to my local dealer and have them grab the parts if they have them so I can physically look at them or to have a stainless line built. I guess I could build my own hard line too. Hopefully I can find the pin that connects the brake booster push rod to the pedal. When I removed it I some how lost it in the cab. Of course the parts diagram doesnt show the pin.
  13. Feb 13, 2023 at 4:45 PM
    SparkyIX
    Anthony
    Tonopah, AZ
    I personally just went with a stand alone clutch system. Fluid resi on fender to the clutch master. Clutch master out to the hydraulic bearing. I used one small oem hardline to connect to the steel braided line to the bearing.
    yeah that pin is tiny, the cylinder with the metal locking clip yeah? I had the same issue, it’s there trust me.
  14. Feb 13, 2023 at 7:15 PM
    dkensk
    dkensk Well-Known Member
    I'm not quite 100% sure, but from my reading, the 6speed uses a front drive shaft that is 1" shorter than the rest of the 4wd tacomas but the auto front shaft seems to work.
    I believe you may need a spacer to retain your DCLB rear drive shaft.
    Or if you have a DCSB/ACLB 6speed drive shaft, possibly use the front half of it and Rear half of the DCLB shaft.
    I will link your thread to mine hopefully help with anyone tackling the project in future
    https://www.tacomaworld.com/threads/2nd-gen-tacoma-auto-to-manual-conversion.778990/
  15. Feb 13, 2023 at 8:39 PM
    #35
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Yea I have the reservoir/bracket/cap/float on order. Should be here around the end of the week. Yes that damn pin was stuck so I used a flathead to pry it out and it shot out somewhere haha.
    Thanks it’s great to have these links to help others out in the future! I have the manual front shaft so I’m good there, though I think you’re right the auto one would work. You make a good point about the front shaft section from an access or double cab. I think the front section of the rear shaft would need to be shortened roughly 1”. Would be cool to get some measurements on an access and double cab short box drive shaft.
    Well made some progress tonight, my brother in law gave me a hand. Just need to pull the cooler lines, couple exhaust bolts and the cross member bolts and out she comes. Toyota went overboard on the tightening of some of the bolts when they replaced the transmission a few years back. Some of the bolts required a stripped bolt head tool just to get them to come out as they would just round from being over tightened. Hoping to tinker on it a little after work this week and hit it hard this weekend.
  16. Feb 14, 2023 at 9:50 AM
    #36
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Sweet project.
  17. Feb 14, 2023 at 10:19 AM
    #37
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You could also use the manual transmission from a 3rd gen which doesn’t have the issues the 2nd gen man trans was plagued with
  18. Feb 14, 2023 at 10:21 AM
    #38
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Thanks! I picked up a transmission a year or so ago for pretty cheap, should I have issues down the road I would defiantly be on the hunt for a 3rd gen transmission.
    Does anyone have a factory manual truck that might have the center console out of for some reason? I would like to get some measurements for the shifter hole instead of just winging it.
  19. Feb 14, 2023 at 10:29 AM
    #39
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I have an '05 MT with a new boot that pops out super easy which I've been meaning to glue in from behind after removing the console. But could be months before I get to that and you're moving fast here.
  20. Feb 14, 2023 at 10:42 AM
    #40
    cfcarpenter
    Clint
    PNW
    2005 DCLB 4wd MT
    Well if you get ambitious feel free to grab some number haha I am hoping to cut the hole before the 6 speed goes in (planning for this weekend). I have a buddy with a manual 06 I am sure he would not mind getting out of the house for a few hours so I could take some measurements.
