auto tranny jerks when shifting into drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jan 20, 2010.
  1. Jan 20, 2010 at 10:06 PM
    ywen
    ywen [OP] Well-Known Member
    When shifting from P to D, the truck sometimes jerks forward fairly strongly.. It doesn't occur everytime.. I haven't figured out what it needs to shift like that (maybe engine RPM?) My 03 Taco has a 3400 V6 with 73K miles. I just bought it used..
    Is this normal?
  2. Jan 21, 2010 at 12:55 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Mine does that sometimes as well, I don't know what it would be though, sorry
  3. Jan 21, 2010 at 1:05 PM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Does it do it when cold or hot? Does it actually move (the truck) or is it more engine moving like mounts or something. I have the same truck and about the same miles, no problems like that. Check your atf level.
  4. Jan 21, 2010 at 1:05 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    My 04 does the same thing. I tend to notice it when I first take it out for a drive, but not always, so I've always guessed it had to do with it being cold. Have you checked the fluid to see if it needs changing?
  5. Jan 21, 2010 at 2:11 PM
    ywen
    ATF is clean and red... I haven't noticed whether it's only doing it at certain ambient temperature..
    Since I have not driven another toyota truck with the 3400 V6.. I only have my Honda Element and my wife's Sonata to compare to.. Those engines + trannies are much smoother...
  6. Jan 21, 2010 at 3:55 PM
    Taco Joe
    Taco Joe Active Member
    Rancho Cucamonga
    01 PreRunner SR5 TRD Debadged
    Black wheels, exhaust, and BFG's
    Mine does it too. But only when the truck is cold.
  7. Jan 21, 2010 at 3:58 PM
    ywen
    does it matter whether you have the brakes pressed down when shifting?
  8. Jan 21, 2010 at 3:59 PM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    I have a 08 V6 and it does it to when it is really cold
  9. Jan 21, 2010 at 4:30 PM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    I don't think you can shift from P to D without pressing the brakes. From Neutral to D ya I think you can. So if you are doing that then yes you will feel a bit of a jerk then especially when it's cold. The truck that is.
  10. Jan 21, 2010 at 4:37 PM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    You're comparing apples and oranges between the truck and element/sonata. Front wheel drive vs. rear wheel drive. Truck base vs car base. So yes it the truck will feel harsh or different.
  11. Jan 21, 2010 at 4:38 PM
    ywen
    right I mean from N to D...
    What would be the inherent difference between a car and truck to cause this difference? not arguing.. just curious..
  12. Jan 21, 2010 at 4:39 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    A firm shift or jerk is good. Dont worry about it.
  13. Jan 21, 2010 at 4:48 PM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    Shift points. Shift logic. Also different gearing.
  14. Apr 19, 2011 at 6:17 PM
    USNavyTaco
    USNavyTaco Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    Mine does this. I just called my friend who works for a tranny shop. He said it's normal to feel a "jerk" because with an automatic. The load is now being placed on the engine to " drive" the car. Whether it be forwards "Drive" or backwards "Reverse". When you are at a stop and release the brakes, the car moves forward right? And when you are in reverse backing up, you release the brakes and move backwards right? Same principle applies here. The jerk is simply u, the brakes, and the frame fighting the engines torque making at attempt to move. This sounds logical to me. He said though if it makes a metallic thunk, or thinks while shifting and accelerating, that this is a sign of a bad tranny mount.
  15. Apr 3, 2012 at 7:01 AM
    pou4518
    pou4518 Member
    Natchez, Ms
    2000 Tacoma, extended cab, 4wd, 177K+
    None Yet!!
    Mine also jerks really bad when shifting from P to D and D to R but I halfway expect that.. What I dont expect is when I come to a stop it will make a hard enough clunk that I can see the gear and four wheel drive shifters move inside the truck. What would be causing that? Bad mounts on the engine and tranny or just the torque of the engine?
