Auto Tranny Off Road?
Discussion in '1st Gen. Tacomas (1995-2004)' started by robbob, Aug 19, 2014.
  1. Aug 19, 2014 at 3:18 PM
    robbob
    robbob [OP] New Member
    bob
    texas
    4x4
    I will be doing the Trans Canada Adventure Trail in the spring in a first gen. That's over 9300 miles, most of it not paved. I did the American version, Canadian border to Mexican border previously in a 2nd gen with a 6 speed and I got tired of shifting. So is there any reason an automatic tranny wouldn't hold up to that kind of abuse?
  2. Aug 19, 2014 at 4:04 PM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    robbob, I don't have an answer for you, but I do tip my hat to you for the adventure ahead of you. I will follow this post as it will be of interest.
    :oldglory:
  3. Aug 19, 2014 at 4:14 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Shouldn't be a problem. Don't see why not. Oh and don't forget that your L gear helps with downhilling provides engine braking. And your 2 gear can be useful in mud and uphill, also switching overdrive off helps on uphill climbs if need be.
    And if the 1st gen has a rear locker then you're good to go.
  4. Aug 19, 2014 at 6:42 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    why wouldnt it be fine?
  5. Aug 21, 2014 at 10:53 AM
    robbob
    bob
    texas
    4x4
    Thanks for the replies. I really don't want to go with a manual. The reason I asked is to find out from the off road pros is an auto tranny can't handle all the shifting that hour after hour and day after day of off road travel will make necessary.
    Robbob
  6. Aug 21, 2014 at 2:43 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    It will be absolutely fine. If you are climbing steep grades and the trans is constantly shifting in and out of OD, then turn off the OD to lock up the torque converter to keep the temps down. Otherwise nothing to worry about.
  7. Aug 21, 2014 at 6:27 PM
    Huntn57
    Huntn57 Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    when off roading in a automatic. i don't off road but i just got my info from hunting and around the farm but anyway u will be amazed in the power differents from drive to low or 1st even in 4 high. go up a steep hill going about 5 mph or so and drop it down its like night and day differecne
  8. Aug 22, 2014 at 4:16 AM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    Won't be a problem assuming your trans is in good shape.
    While i have never ran the trail I did have a chance to drive to Alaska back in 06. A buddy moved up there and it wasn't hard to convince me to go considering I had been looking for a reason to make the drive.
    Not sure what the roads are like today but back in 06 a good portion of the trip was on gravel and badly maintained " highways". My 03 Tacoma had no issues with the trip but I did find myself running a good portion of the trip with the OD off as the trans was hunting for gears but we did have a lot of weight in the truck. THe trip back was much easier as the truck was about 800lbs lighter.
  9. Aug 22, 2014 at 7:46 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    This ^^^
    Went to the Alpine Loop last month and spent two days wheeling out there at 5-10 mph all day. Up at 12k ft you need 4LO more often than not as I was down on power. On road between Silverton and Durango, I was more worried about toasting my brakes going down hill. I kept it in 2nd down hill and going up I had to keep the OD off. It's also way cooler up there I had no issues with the auto. 1st gear in 4lo was my best friend all day long.
  10. Aug 22, 2014 at 8:01 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Do you know what many competition rigs run these days ? Automatics !! That tells a lot.
    From my own experience, it works as well, if not better, than a standard, while offroading.
    On one rock-crawling trip in the Mohave, with most other guys having a clutch and crawler gears, they were surprised at how well I did with my auto, stock gears, and stock transfer case. When going over an obstacle, they would be spinning tires, riding the clutch, and stalling. With the auto, there is no stalling or revving up the motor. Autos really make up for not having a crawl box.
    I've never had a problem with overheating either, after 4 years.
    Just my personal experience.
