auto tranny questionsI have a new
Discussion in '3rd Gen. Tacomas (2016-2023)' started by easygoing, Aug 2, 2019.
  1. Aug 2, 2019 at 3:45 PM
    easygoing
    easygoing [OP] Member
    2018 TRD Offroad
    I have a new 18 offroad v6 with auto tranny. question #1/how can I go about draining ALL the fluid from the tranny as I want to switch to amsoil & want to get as much of the factory oil out as possible? I realise I won't be able to get all the old oil out but as much as possible. q2/ I understand to pin the temp. pin in & use an allen wrench through the holes to keep it pinned open. q3/ If I use a temp probe to register the tranny temp coming from the check hole, after the refill to obtain the proper oil level, why do I need to apply the paperclip under the dash? This is my first taco & am very impressed with it!! thanks
  2. Aug 2, 2019 at 4:45 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Trans and transfer case are very picky. WS Fluid only in my toyotas. that being said, drop the pan>remove the drain plug
  3. Aug 2, 2019 at 4:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    Will not empty converter. Maybe 1/2 the volume if lucky?
  4. Aug 2, 2019 at 4:50 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Do yourself a favor leave it alone.
    Chew, JCT86, eurowner and 3 others like this.
  5. Aug 2, 2019 at 4:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    https://www.tacomaworld.com/threads/changing-own-transmission-fluid.521510/#post-21073722
    While this is a bit dated, it does offer WS alternatives.
    https://www.tacomaworld.com/threads...a-ws-atf-automaitc-transmission-fluid.373083/
    If your truck is new as you say, I'd check the level and let it go.
    At 30k intervals drain and fills will be adequate to keep all the additive packages fresh. And that's using the truck pretty hard.
    There is nothing wrong with Amsoil as a choice. But there is nothing magical about it that makes it worth boutique prices either.
  6. Aug 2, 2019 at 4:56 PM
    Bishop84
    Bishop84 Well-Known Member
    Fluid is not an issue with Toyotas, it's already synthetic and I have never seen it break down.
    Only way to fully drain is remove converter, drop pan, drop filter. Huge waste of time and money.
  7. Aug 2, 2019 at 5:03 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Just make sure it’s full of WS. Leave alone. Change fluid at recommended mileage and you will continue to be impressed as I am with mine. ‘18 OR.
  8. Aug 2, 2019 at 5:16 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There are threads on TW about how to change all the auto trans fluid.
    Basically you disconnect the fluid line at the trans fluid cooler. Drain the trans pan. Fill the pan. Run the trans until 3 quarts of fluid comes out the the trans cooler line. Add 3 qts of fluid to the trans pan. Repeat until 11-12 quarts of fluid is replaced.
    Some use a garden spray tank to pump the trans fluid simplifying the stop, fill, start steps.
    Me, I started annual pan drain & fills after 40k miles. Using Valvoline MaxLife.
