Auto tranny to Manual tranny
Discussion in 'Technical Chat' started by jacob_wood, Apr 25, 2010.
  1. Apr 25, 2010 at 12:01 PM
    jacob_wood
    jacob_wood [OP] Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    Has anyone with an 05+ Tacoma done a automatic transmission conversion to a manual transmission? If not does anyone know of any threads? I'm looking specifically for 05+. I have read multiple threads that deal with older Tacoma's but I'm not too sure if anything changes between the different generations.
  2. Apr 26, 2010 at 4:55 PM
    jacob_wood
    Jacob
    2010 SSM DCLB
    Anyone have any info?
  3. Apr 28, 2010 at 10:51 PM
    ellocodetroit
    ellocodetroit Well-Known Member
    Detroit
    Chino Hills, So Cal
    SR5 PreRunner
    Buddy Club grounding kit, Afe Pro Dry S air filter, Rear suspension TSB, Aftermarket HU, Alpine 6.5" speakers, Fosgate Amp, Hardwired GPS charger, Weathertech Floorliners, Bilstein 5100 Front shocks @1.75"
    I converted my old auto Honda Civic to a manual tranny about 4 yrs ago. It was a pita. Im sure you will need at least the following:
    manual tranny ECU
    clutch pedal
    master and slave cluch cylinder
    manual tranny
    tranny mounts(if the manual tranny does not mount with existing auto mounts)
    maybe a subframe????
    manual shifter
    you will need to wire the reverse light to work right
    cruise control might need to be rewired
    keys need to be refalashed with new ECU
    manual tranny wiring harness
    cut a hole on the firewall for the clutch pedal
    24 pack of beer
    advil
    band aids
    and patience
    It's a whole lot of work, which I do not recommend. I have no experience on a transmission swap for a Tacoma. I sure it's about 75-80% the same. Honestly you will be better off buying a manul transmission truck or have a shop do the swap for you. Good luck.
  4. Apr 28, 2010 at 11:31 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    The best (only) plan is to sell your truck and buy one with a manual trans.
    Sure, it would be a fun challenge I guess, but besides the tremendous costs involved, it's going to be complicated and will most likely always have problems/issues afterwards.
    To give you an idea of what all might be involved:
    - Transmission unit
    - Driveshaft bushings
    - Radiator
    - Engine manifold
    - Driveshaft (I believe the manual and auto have different lengths)
    - Transmission mounting plate
    - Linkage components
    - Pedal assembly
    - EGR valve
    - Vacuum modulator
    - Gear ratio (different on auto then manual)
    - Sensors and rewiring
    OK, that's just me getting started.. this list would be freakishly long.
