Auto Trans - 93k - Should I do a 4 Qt. D/F or do at home flush?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MoonCrawler, May 10, 2016.
  1. May 10, 2016 at 5:43 PM
    MoonCrawler
    MoonCrawler [OP] Well-Known Member
    Sacramento, CA
    2003 Tacoma V6 4x4 TRD
    It's an '03 with an auto trans. I haven't had it too long, so I don't know if the fluid has ever been serviced. I believe it had 30k and 50k services done at dealership, but not really sure what they did at those dealerships as I didn't own the truck then. It doesn't smell burnt, but when I added a trans cooler the other day, the fluid that was lost looked dark. I'd like to replace it.
    I know opinions will vary. Should I do a series of 4 qt. drain and fills *OR* disconnect the send and return hoses at the radiator and feed 12 qts (roughly) of new fluid into it using its pump to do the work, thus changing all the fluid at once? I'm not sure if the second option is considered a flush or the kind of flush that could be harmful.
    Real world experience trumps technical chat.
  2. May 10, 2016 at 6:46 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    4qt drain and fills. Just my opinion and what ive done to may trucks and buddies cars.
  3. May 10, 2016 at 6:48 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
  4. May 11, 2016 at 12:28 AM
    MoonCrawler
    Sacramento, CA
    Thanks for chiming in. I think that's the way I'm going to go. I'm not trying to learn (or re-learn) a lesson with this truck.
  5. May 11, 2016 at 6:56 AM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    LOL, thats how I felt about it when I was working on it. It sure did like a taste of the synthetic tranny fluid though.
  6. May 11, 2016 at 7:02 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Drain and fill.
    Do it again in the fall if you. Have an OCD condition.
  7. May 11, 2016 at 8:13 AM
    prayzhm
    prayzhm Active Member
    Bob
    2004 Tacoma Dbl Cab TRD
    My truck had 97k on it when I did 12qt flush with synthetic AT fluid and it shifts like a dream. I too didn't know if the previous owner had done any maintenance as the owners manual was untouched. the fluid did look dark and not burnt so I thought I'd go for it.
  8. May 11, 2016 at 8:20 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    My opinion, drain the pan. Then drop the pan and remove the filter. Clean both thoroly. You will see the magnets in the trans pan covered in shavings, clean those. Replace whatever gasket there is for the pan. Be prepared, have new drain plug handy, have all torque specs. I know the pan bolts are a low torque, like 25 inch#'s and the filter bolts are close to the same. Do this at your next oil change, then again at the next. This will catch a large majority of contaminants in the trans. Then after these two cycles, you should only have to do drain and refills.
  9. May 11, 2016 at 10:17 AM
    MoonCrawler
    Sacramento, CA
    What kind of synthetic fluid did you use? Did you also add any additives (like lubeguard)? A few years back I had a '99 with an auto trans. I did a series of drain and fills using Redline D4, with no other additives. At first it seemed to make it shift better, but over a few months it started shifitng hard (especially in the heat). I didn't keep the truck very long after that and I don't really know if the trans already had problems before the Redline or not. But when I replaced that truck with an '03 with auto trans, all I ever did was do a drain and fill at each oil change using only Toyota Type IV. That trans never had a problem. Then I hit a deer at 70 mph so that truck took its perfect tranny up to Toyota heaven.
    Now I have this new one and my current dilemma. Flush, don't flush? Drain and fill? Synth or Toyota only?
    When I told the above story to a mechanic who works at a trans shop, he told me that there are additives in Toyota brand fluid. So, if you use something else, you are supposed to add lubeguard to it. I'm not sure he was the best guy for info though.
  10. May 11, 2016 at 10:24 AM
    MoonCrawler
    Sacramento, CA
    Unfortunately, my current living arrangement doesn't give me the opportunity to drop the pan. (Apt. with public parking area.). Drain and fill type work is fine, but flatbacking, removing the pan, and exposing the underside of the trans might not be the best idea right now. I could see a gust of wind splattering the underside of the trans with a spray of dust/sand. I also don't have a solid work area or bench.
    I want to do it but I think I'm gonna have to wait until I'm somewhere else, or meet someone in the area with the space and tools. I would like to see whats on the screen.
  11. May 11, 2016 at 10:24 AM
    MoonCrawler
    Sacramento, CA
    What type of fluid did you use?
  12. May 11, 2016 at 12:19 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Could always wrap the exposed areas with plastic and masking tape. It is a pain to do that work in a parking lot though.
