Auto trans clunks into first at stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gage, May 31, 2011.
  1. May 31, 2011 at 2:24 PM
    Gage
    Gage [OP] Active Member
    Hi All,
    I've been having an issue with my truck and I'm not sure what the culprit is. It's an 03 3.4 Auto with 122k on the odo
    WHAT IT DOES
    If I come to an abrupt stop it sounds like the transmission does not shift into first and when I roll forward it "seems" to shift but it shifts hard. To be honest I don't know if it is actually shifting or not. the trans lever moves ever so slightly when this occurs. No other drivability issues and the fluid was swapped standard drain and fill (NO FLUSH) about 2k miles ago.
    WHAT I THINK IT MIGHT BE
    I did a lot of searching and I think it could be the slip yoke not moving freely in transmission or the trans is completely fucked up. I plan to grease the zirk fitting tonight and see if that helps.
    I'd really appreciate everyone else's thoughts on this and for anyone who has owned one of these trucks longer than me to chime in as to whether this is a common problem or not.
    Thanks in advance
  2. May 31, 2011 at 2:40 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Pretty sure its the axle wrap issue a lot of people have with the 1st gens. Get new leaf springs or just add some helper springs and it should go away. Does it with my truck too, but not really that bad.
  3. May 31, 2011 at 3:40 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    What about the U joints?
  4. May 31, 2011 at 6:03 PM
    Gage
    I checked them by trying to twist the axles in opposite directions and didn't detect any significant play.
    Is that how you test them?
  5. May 31, 2011 at 6:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm probably wrong and I'm sure I'll hear about it but it sounds to me like the TCC (torque converter clutch) switch is failing if its not down shifting at a stop. You're lucky it eventually does but eventually it won't. I'm not sure whether it's in the pan or accesible from the side.
  6. May 31, 2011 at 6:52 PM
    antler3649
    antler3649 Member
    Eric
    Yellowstone Natl Park
    From all of the reading I've done around here, my bet is with axle wrap. Do a search and see if your issues mimic the hundred or so threads on it.
  7. May 31, 2011 at 6:56 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    It sounds like axle wrap. I had the same problem feels like someone hit you from behind. Problem went away with new springs.
  8. May 31, 2011 at 6:56 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This^^ I've seen tons of threads about axle wrap on the 1st gens. You could get helper springs or get your leafs re-arched.
    Here's a link on how someone else fixed theirs.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/108316-goodbye-axle-wrap-mod.html
  9. May 31, 2011 at 7:36 PM
    Gage
    I'll do a search on axle wrap - the leafs are pretty much flat anyways but I wasn't quite ready to get my lift...
    does having axle wrap hurt anything?
  10. May 31, 2011 at 11:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  11. Jun 1, 2011 at 7:56 AM
    Sign Guy
    Sign Guy Well-Known Member
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Nice Rims, Big Tires, Carryboy Shell, Added Rosta Cruise Control & Ultraguage, 5100 Bilsteins All around
    Thanks a lot, I think I have the issue and don't particularly care to "lift" my prerunner any higher. I like the stock height and this looks perfect for my application, even just the U-bolts. I did order some new 51XX series bilsteins which should arrive today so we'll see what those do to my suspension.
  12. Jun 1, 2011 at 8:29 AM
    sxgt
    sxgt Member
    03 DC SR5 4WD TACO
    I had the same issue (03, 140k miles) - thought it was axle wrap and replaced the suspension. It was still there. Lubed the slip joint which was completely dry I think - problem went away for about 3-4 weeks. It is slowly coming back - so I believe the seal on the slip joint has loosened up over time. I am not sure if it needs to be replaced or just lubed regularly.
    Cheapest check is to try the slip joint and go from there. Make sure to lube it until you see the lube start to come out. If it is dry - it will take a lot to fill it.
    Edit - Slip Joint is not the proper term. I am not sure what it is called, but it is on the drive shaft and when you fill it the draft shaft starts to slide apart until the lube comes out. Here is the link to the diagram I used to lube the joints on the front and rear drive shafts:
    http://ncttora.com/fsm/2003/Repair_Manual/03tacoma/ma/chas/insp.pdf
    All told between both shafts - it was probably 6-10 fittings.
