Auto trans has a hard time shifting to 3rd when COLD
Discussion in '1st Gen. Tacomas (1995-2004)' started by DNG, Apr 6, 2012.
  1. Apr 6, 2012 at 6:23 PM
    DNG
    DNG [OP] Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    When starting my engine cold (morning cold), my truck has a hard time shifting to 3rd. I'll run at 2000+ rpm in 2nd but won't shift to 3rd unless the engine has warmed up a bit. This problem just came up a couple months ago. Any ideas?
  2. Apr 6, 2012 at 6:29 PM
    DNG
    Orange County, CA
    I used to be able to drive just fine even when cold. Never had to push such a high rpm
  3. Apr 6, 2012 at 6:34 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Mine does the same. I believe it does this to warm up the truck properly before hitting high speeds.
  4. Apr 6, 2012 at 6:38 PM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    Mine does that from 1st to 2nd, and then 2nd to 3rd. After 10 minutes or easy driving it warms up and is fine.
  5. Apr 6, 2012 at 7:57 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Flush the fluid. The transmission is designed to do this to allow the engine to warm up, but as the fluid gets dirty the system doesn't work as efficiently.
  6. Apr 6, 2012 at 8:25 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    The purpose of holding it in a lower gear when cold is to get the Catalytic Converter to operating temperature as quickly as possible. Cold start and warm-up are high emission periods and Toyota needs to get the cats "lit" ASAP. The owners manual mentions the delayed shift to 3rd when cold.
  7. Apr 6, 2012 at 9:50 PM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    Mine with the 3.4 does the exact same thing.
  8. Apr 7, 2012 at 3:09 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    my 3.4 auto does the same as well. after how many miles should tranny get flushed?
  9. Apr 7, 2012 at 4:25 PM
    DNG
    Orange County, CA
    I haven't done a flush yet, and I don't know if the previous owner has (150k mi). I also haven't found a conclusive answer on whether flushing the trans fluid is safe or if it's better just to take the whole pan off.
