Auto Trans in the mountains
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mudchomp, Sep 3, 2017.
  1. Sep 3, 2017 at 8:47 PM
    bluenv
    bluenv Well-Known Member
    My second gen MT climbs mountains all day in 5th and 6th and doesn't lug. I only have to drop to fourth on grades over 10% and never third.
  2. Sep 3, 2017 at 9:34 PM
    BeanDip
    BeanDip Well-Known Member
    Frank
    2017 TRD Sport DCSB Auto
    I have problems with my auto trans and towing my utility trailer just around town on flat lands here in SLC basin.... forget towing up in the mountains!
  3. Sep 3, 2017 at 10:43 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    I just got back from Sequioa National Forest with my V6 auto TRD OR and didnt really notice any issues driving up. I also liked that I can throw it into S and keep my trans in 1st and 2nd when going down the really twisty one lane sections. ECT was on the whole time for me as well, and I just let the truck do it's thing when going up.
    I don't know though, cause this is my 1st truck ever so it's all I know.
  4. Sep 3, 2017 at 11:00 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Shift sense fixed a lot of my issues. 35's and stock gearing was a little rough even with that thing. Once regeared even 37's are fine.
    It's a pretty cheap fix at less than 200 bucks.
  5. Sep 3, 2017 at 11:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Talk about a turd of a diesel, that might be the only time I pick third gen Taco over literally anything else haha.
  6. Sep 3, 2017 at 11:33 PM
    Syncros
    Syncros Well-Known Member
    Same with my Frontier Pro-4x 6mt.
  7. Sep 3, 2017 at 11:38 PM
    Syncros
    I dunno, I used to drive a 6.5TD GM 3500HD for work and never felt it was under powered. If we're talking build quality, then yes.. Agreed.
  8. Sep 3, 2017 at 11:52 PM
    cdthiker
    cdthiker Well-Known Member
    Tim
    WAY north Idaho
    2012 Tacoma RC 4X4 5speed
    Makes me glad I kept my 2012 2.7 4x4 5 speed. 4th gear and 65 all day long at all but the steepest grades that are over a few miles long, 3ed will run up to 4 k
    Get a manual problem solved, or a second Gen.
    All joshing aside, the above comments about rpms and gearing is correct, you can always also try slowing down a bit if you do not want to listen to the high RPMs but unless you have to drive it every day, id say stick with the 17, they are good looking trucks.
    just my .02C
  9. Sep 4, 2017 at 6:54 AM
    eurowner
    eurowner Duke Sky
    Scoty
    The way I built the 6.5, it was goofy quick, would never drop into 3rd going over any pass in CO at 63mph using cruise control.
    Now my '85 GMC K3500 SRW Sierra with the 6.2 and manual is much slower.
  10. Sep 4, 2017 at 8:43 AM
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2021 Cement TRD OR DCSB
    Truxedo Pro X15 tonneau, front tinted windows
    Op, the trans shifting gets better after 1200 miles or so. If not, go to the dealer and request the TSB. It makes a big difference. I had similar problems. I'm often in the Poconos (I know, you guys out west laugh and say what mountains to what we have here east) but it's much improved. Not perfect, but much improved. I actually love my truck now...finally.
    Stocklocker and Hiluxski like this.
  11. Sep 4, 2017 at 8:51 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Just let it scream. Put it in the gear that gets the job done and go. I drive Mt. Mitchell out here all the time and force the truck to use 2nd or 3rd on the steep curvy roads. Revs high, but does just fine. If 4th is wanting to downshift to 3rd, you should have been in 3rd. If you can't get used to it, you might need a different truck.
    Nature of the beast.
    G.
    eurowner likes this.
  12. Sep 4, 2017 at 9:04 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Looks like somebody needs to study the Transmission Software Update TSB thread. Typically, for many of us, the Transmission gets worse once it "learns"...it behaves better when the ECU has just been flashed or updated. After 3k or 5k miles it reverts back to crummy shift patterns.
    speedtre and Kilokato like this.
  13. Sep 4, 2017 at 9:13 AM
    Mudchomp
    Mudchomp [OP] Member
    Dixon, CA
    My truck was built in 02/2017. Since the 0077-16 Rev.1 was released on November 15, 2016, don't you think my truck would have had that from the factory?
    I'm cool with letting the truck live in 3rd when climbing or when climbing with slow traffic in front of me like what was going on yesterday, but I think I'll try out the Shift Sense Pro and see if those more linear shift patterns will do the trick and I won't have to futz with sequential shifting as much. I kept thinking, man a 3.5 gear would be awesome.
    03 NIGHT TACO likes this.
  14. Sep 4, 2017 at 9:16 AM
    Mugsy7
    Mugsy
    Delco, PA
    Nope. No need to study on my experience. Had two TSBs. Rev 1 being the last.
    And like I said, not perfect but much improved. 4-5-6 will continue to search on hills and acceleration because to the gear ratio. But it hasn't been as bad since Rev 1. Prior to, it was all over the place. Again, my experience.
    BillsSR5 likes this.
  15. Sep 4, 2017 at 9:24 AM
    #35
    smitty99
    Scottsdale
    Well that's one. ;)
  16. Sep 4, 2017 at 9:25 AM
    #36
    smitty99
    Scottsdale
    2017s weren't coming with LCA plugs even though it was a TSB already on the 2016s....so no I wouldn't assume anything
    Kilokato, Hiluxski and Garyji like this.
  17. Sep 4, 2017 at 9:27 AM
    #37
    Garyji
    Gary
    If you are trying to use 5-6 on any hills, you will be disappointed! It will not "learn" to make you happy in that scenario!
    Doing the 7% grade East of Hendersonville I can easily do 70 in 4th with no problem.
    However . . . you do have to actually drive it and not let the trans think for itself.
    G.
    Stocklocker likes this.
  18. Sep 4, 2017 at 9:30 AM
    #38
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I've taken mine into and over the Rockies a few times now and no issues either. I think I just put it into S mode and left it at 4. Used manual downshift a few times as needed.
  19. Sep 4, 2017 at 9:37 AM
    #39
    Garyji
    Gary
    That's how to do it.
    G.
  20. Sep 4, 2017 at 9:47 AM
    #40
    Jajones Man
    Jajones Man One of the few "Southpaw's" still around.
    Jake
    Eastern Oregon
    2017 Quicksand DCSB M/T
    Do the sensible thing, get a manual transmission and turn that truck into a man handling beast, no mountain will dare to throw problems at your beautiful killing machine of a 6 speed.
    dnlskier and shakerhood like this.
