Auto trans issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MyTaco, Nov 12, 2011.
  1. Nov 12, 2011 at 11:34 AM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Hey guys, 08 double cab V6 w/auto trans, no leaks only 40k miles when at a stop it occasionally feels like the trans goes in and out of gear like you've manually moved the selector from neutral to drive. Anyone experience this?
  2. Nov 12, 2011 at 11:35 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    try check trans mounts to see if any bolts loose. try grease drive shaft if applicable. could u possibly be feeling idle up from engine?
  3. Nov 12, 2011 at 11:37 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Are you running the A/C when you experience this by any chance?
  4. Nov 12, 2011 at 11:39 AM
    myname150
    myname150 Well-Known Member
    x2
    this is what first came to mind. A/C compressor kicking in.
  5. Nov 12, 2011 at 11:39 AM
    MyTaco
    Az
    08 Prerunner
    It's a buddy of mine who owns this. I'll have to ask him those questions. I cant imagine this thing idling so low that the a/c surge would do that. He said it actually clunks like putting it in gear.
  6. Nov 12, 2011 at 2:15 PM
    Leer
    Leer Well-Known Member
    Lee
    Hilo HI
    2015 Tacoma 4x4
    I have the same issue. Try searching axel wrap. I'm pretty sure this is what you are experiencing.
  7. Nov 12, 2011 at 2:32 PM
    MyTaco
    Az
    08 Prerunner
    Axle wrap with the truck standing still?...explain?
  8. Nov 12, 2011 at 3:43 PM
    myname150
    Yeah, first time this happened to me was at a stop, in Drive and the A/C compressor kicked in. Slight "clunk". Like going into gear from Neutral to Drive.
  9. Nov 12, 2011 at 4:12 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Is a normal function of these trucks. The a/c makes it worse. It seems to me that it's the transmission shifting to 1st gear once you stop and/or the a/c compressor cycling. Both my Tacoma and 4Runner do this. Nothing to worry about, just make sure that when you stop at a light you have your foot pressed on the brake pedal good cause sometimes it jumps forward a little.
  10. Nov 12, 2011 at 4:31 PM
    MyTaco
    Az
    08 Prerunner
    No it's bone stock. How the hell can the axle wrap when it's still under tension in drive???...makes no sense!
  11. Nov 12, 2011 at 5:52 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Don't sweat it. Our FJ has the auto trans. Sometimes we'll be at a light and the tranny will eventually decide (they must have a brain of their own... ) we're actually stopped and there will be a perceptible "bump" like you describe. I just think our trannys are not as smooth as some big American cars are.... after all, we're driving trucks, not cars!
    I wouldn't worry.
  12. Nov 13, 2011 at 9:06 AM
    MyTaco
    Az
    08 Prerunner
    Dont take it personally, I was a mechanic for 10+ years at a GM dealership. I understand what axle wrap is just didnt make sense on feeling a thud with your foot on the brake and not moving. One of those links mentioned the tranny "hunting" for a gear after it stopped...sounds more like that. Thanks for all the links, much appreciated.
  13. Nov 13, 2011 at 9:07 AM
    MyTaco
    Az
    08 Prerunner
    yes I do but it's a 6 speed.
  14. Nov 13, 2011 at 9:13 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Totally agree with the a/c kicking in. Same thing happens on my truck. And remember, when you use the defrost option, the a/c is actually on.
  15. Nov 13, 2011 at 10:14 AM
    JKD
    JKD Well-Known Member
    Combine the normal trans shifting down to 1st gear after you stop with old and starting-to-wear U-joints in the driveline and you would get what your friend describes.
