Auto-trans jumping out of reverse
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmexyz, Dec 1, 2011.
  1. Dec 1, 2011 at 3:39 AM
    jmexyz
    jmexyz [OP] New Member
    Maui, Hi.
    02 lifted 4dr.
    7in.lift, warn hubs, k&n intake, red top optima batt.
    I have a 02 Tacoma and when ever i'm in reverse and i hit the gas it seems to jump out gear. Basicly at the start of reversing cause if i slowly start to go it works fine but if i try or have to give it a little more gas than normal it jumps it to nuetral. Any ideas on this problem?
  2. Dec 1, 2011 at 5:45 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    shift cable out of adjustment . does it do it in any forward gears
  3. Dec 1, 2011 at 6:05 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Broken motor mount, raise the hood so you can see the engine while you are inside the trk, start the engine put trans in drive, foot on the brake,( power brake ) slightly raise the engine RPM's and do the same in reverse and see if engine raises, be careful if there is a broken mount the fan may chew up the radiator shroud.
