Auto trans not shifting passed 3rd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jainuss, Nov 22, 2020.
  1. Nov 22, 2020 at 12:59 PM
    Jainuss
    Jainuss [OP] Active Member
    2013 tavoma prerunner
    I did the tranny service and I followed the links I found on this site. My issue is the tranny will not change from third. I put it back in temp test mod and it shows over hot. I check the overfill while on and it drains fluid. What am I doing wtong? Does the temp light have to stay steadily on in order to check correct level? Any help is greatly appreciated
  2. Nov 22, 2020 at 1:02 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Well, If it shows over hot then it’s to hot to check. Ya gotta let it cool down and re check.
    SR-71A likes this.
  3. Nov 22, 2020 at 1:03 PM
    Jainuss
    So I need to cool then redo temp check and when light is solid check level?
  4. Nov 22, 2020 at 1:08 PM
    spitdog
    Yes, You should just check it first thing in the morning. It takes a long time to cool if the ambient temp is above 50 or so. When its solid, check it with the engine running. When flashing, to hot.
    SR-71A and CygnusX191 like this.
  5. Nov 22, 2020 at 1:10 PM
    Jainuss
    Thank you so much for the help. I've been stressing lol
    spitdog likes this.
  6. Nov 22, 2020 at 1:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You aren't in limp mode are you? You will have check engine lights if you are.
    12TRDTacoma likes this.
  7. Nov 22, 2020 at 1:15 PM
    Jainuss
    How do I check that? Scan tool?
    Will it go into limp mode if fluid level is incorrect
    No engine light on dash
  8. Nov 22, 2020 at 1:36 PM
    gearcruncher
    Canadain bumper technician
    Sometimes transmission codes require going into the ecu using a scanner , scan guage or ultra guage and then clear the codes . Codes will not be illuminated on the dash unless you are polluting the air .
    There is a good chance you have some transmission codes that were created while doing the transmission service. This is fairly common
    Clear the codes and you should get overdrive as well as lock up again . You could also try popping the battery cables off for a while but this depends on soft or hard codes . As mentioned above , you are most likely in limp mode .
    Is your transmission the 5 speed automatic or the 4 speed auto ?
    Ilovetac05
    Lowell . This is your problem
    PzTank and Jimmyh like this.
  9. Nov 22, 2020 at 1:48 PM
    Jainuss
    Thank you for the post. I'm a 5 speed auto
  10. Nov 22, 2020 at 1:53 PM
    gearcruncher
  11. Nov 22, 2020 at 2:25 PM
    Jainuss
    Yes pan was off and replaced the filter. Has 118k
  12. Nov 22, 2020 at 2:29 PM
    gearcruncher
    Some guys have been known to squash or cut the wires going to the solenoids when they tighten the filter back up or they accidently knock the wiring going through the transmission casing out of place . The wiring gets incredibly brittle after years of hot / cold / hot cold .
    Got my fingers crossed that you dont have to take the pan back off :fingerscrossed:
    Steves104x4 and 12TRDTacoma like this.
  13. Nov 22, 2020 at 2:48 PM
    Jainuss
    Will that show up on the Scan tool
  14. Nov 22, 2020 at 2:58 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Our transmission pan takes 3 quarts to fill. I do a drain and fill at this point and don't even bother checking level after filling it now, and I definitely don't bother putting the truck into "transmission fluid level check mode."
    Honestly the difference between "hot to the indicated manual temperature" in comparison to just hot to operating temperature is negligible as far as fluid level goes.
    If you are indeed in limp mode it would be best to reset any associated codes and if you have the capability to, even potentially perform a transmission relearn.
    Otherwise, if you did remove the transmission pan (for whatever reason) just to do a service and you did pinch the wiring as suggested above then you will have to remove the pan once again and fix the wiring. Hope it pans out for you (no pun intended, okay maybe sort of)!
  15. Nov 22, 2020 at 3:05 PM
    Jainuss
    I hope I didn't pinch the wires. I'm gonna put a scantool on it now and hope its good enough to to do the relearn. Thanks all for your help. I just dobt have a good feeling
  16. Nov 22, 2020 at 3:27 PM
    Jainuss
    Ok i cleared codes. And doing the temp check deal. Anything I am forgetting gents? The code showed stuck solenoid but I'm hoping g its just because I was messing around in there
  17. Nov 22, 2020 at 4:52 PM
    Jainuss
    Ok cleared codes took it for a long test drive. Streets and freeway, no issues. In the back of my mind I'm worried it will pop up again. Odds? And thank you guys fir all the help I super appreciate that
    PzTank and gearcruncher like this.
  18. Nov 22, 2020 at 5:07 PM
    gearcruncher
    Glad that's all it was . Could have been worse ..... I have seen it many times . Helped a lot of members in the past with the same problem .
    I am assuming everything was fairly clean in the pan ?
    PzTank likes this.
  19. Nov 22, 2020 at 5:19 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Just get a OBD Bluetooth reader and download torque app or fusion app. Get the pdis to read temp instead of messing with jumping a wire in the OBD port. The 2.5 Gens temps are 97-115. Drain the pan in the morning. Measure what comes out. Add a .5-1.0 more to that total. Run the engine till you get your readings. Take the check plug off. If fluid trickles out your done. If not let cool and add more fluid. Redo temp check.
  20. Nov 22, 2020 at 5:20 PM
    Jainuss
    Yes pan was clean minus the normal magnet junk. Again I have to express my gratitude to you and everyone else. Lifesavers
