Auto trans oil change interval
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Jun 21, 2015.
  1. Jun 21, 2015 at 3:48 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    How often does the transmission fluid need to be changed. I'm creeping up on 90k miles and have had this truck since 74k and have no idea when or if the transmission fluid has ever been changed. The fluid looks and smells clean. I am pretty soured on the idea of having it flushed, last car I had a flush done on wrecked the transmission. If I should go this route, where should I have it done? I haven't, nor do I plan to do any towing with this truck, I have a 7.3 Powerstroke for anything towing related. But who's to say the PO didn't use it for towing. I recall it having a 3 way hitch in it when I got it that had been in the receiver so long it had rusted in place and had a hard time getting it out.
    18889_581098172032186_795200762348117516_16e7f6a6311635e58000ad39c30fdd9248c68af2.jpg
  2. Jun 21, 2015 at 6:05 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I bought a case of toyota transmission fluid and just drain the pan...4 qts and refill every 20,000 miles or so. My fluid looks like the day I bought it in 04. I drive the shit out of it too...lol
  3. Jun 23, 2015 at 6:23 AM
    Voyager
    Voyager Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    Although mine looks good too, I'm doing a "drain and fill" shortly to prep for a long trip pulling an enclosed motorcycle trailer through the mountains.
    My 2004 uses T-IV fluid. I bought Toyota T-IV.
    I would not do a flush if your fluid looks ok.
  4. Jun 23, 2015 at 8:16 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    my rule of thumb on auto trannys is when it gets to 100k flush and replace with full synthetic fluid and do it again at 200k if you get there
  5. Jun 23, 2015 at 1:52 PM
    DestroyerLite
    DestroyerLite Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    With me its when its no longer bright pink and starts to smell slightly burnt. I have had my 04 since brand new off the dealer and just changed it a few months ago and I am only at 57K on the ODO, but the pink was no longer pink it was a little too dark for my liking. So basically look at it and make the determination.
    Also I recommend a drain and fill I have never done a flush so I can't say what it does but a drain and fill never did anything bad to my vehicles.
    --Dan
  6. Jun 23, 2015 at 1:57 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    every 30k
  7. Jun 23, 2015 at 2:14 PM
    keakar
    karl
    louisiana
    when you drain and refill, you only change half the fluid, this is because everything in the valve body, torque converter, and lines, is still full of old dirty and worn out oil.
    flushing uses the tranny oil pump to pump fresh new fluid through the entire system so you finish with the whole tranny having fresh "new" fluid that isn't mixed with old fluid.
    but im speaking in terms of a daily driver that isn't abused so towing heavy loads and abusing it will mean the need to have oil changed sooner
  8. Jun 23, 2015 at 2:48 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Mine is looking pretty worn out. I've put 40K miles on it since I bought it at 130K miles. I'm going to do a drain and fill next week along with new diff fluid in both diffs and transfer case and oil change, alignment and maybe balance the tires (I have a bit of a vibration) and maybe flush the radiator as well.
  9. Jun 24, 2015 at 4:08 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    i do mine every 30k. In your situation, I'd D/R several times in a row with some short mileage inbetween until you feel that the fluid has been for the most part replaced.
  10. Jun 24, 2015 at 4:29 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Planning to do mine soon. I have about 155k I bought it at 138k not sure if the PO ever did a flush. I checked the fluid and it was still red and didn't smell burnt. But because it has so many miles and I don't know if it has ever been flushed, I'm planning to just drain and fill. gonna drain and fill it every oil change for 3-4 times in row.
  11. Jun 24, 2015 at 4:37 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I had it done at 100,000 and I just did it again at 208,??? Glad I did, it needed it. I flushed the whole system. There is a write up on how I did it on my build page. Pretty easy.
  12. Jun 25, 2015 at 2:02 AM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    follow the owners manual
