Auto Trans question- 80-90 wt gear oil usage
Discussion in '1st Gen. Tacomas (1995-2004)' started by MichaelL, Jun 18, 2013.
  1. Jun 18, 2013 at 4:11 PM
    MichaelL
    MichaelL [OP] Member
    Michael
    Oregon
    Tacoma LX
    Hello-
    1997 tacoma, 2.4 L, extended cab, auto trans, 125K miles.
    80-90 weight gear oil was used when transmisson oil was was drained
    (app. 2 qts) . Drove about 10 miles and then drained again (2 qts) and added Napa Dexron 3 ATF.
    I was thinking about changing it again in about a week, but after cruising all over the web, it seems
    like it might be a waste of time as 80-90 wt valvoline gear oil seems like a good use in trannies for some folks.
    Does anyone have experience with this please?
    More than likely I will drain again in a week. It is so easy to do.
    Thanx
    Michael
    PS - will not get it flushed no matter what.
  2. Jun 18, 2013 at 9:27 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    80w-90 in an *automatic* transmission? That's…surprising.
    80w-90 usually runs in the 14-16 cSt range (100 celsius). Dexron-III ATF, by comparison, usually runs 7.4 to 7.7 cSt (also @ 100 celsius). You dropped something twice as thick (at or near max. operating temp) in your auto transmission as what it likely calls for. It called for water, and you added room temperature honey.
    I guess if it *works* for you, great. I'm not recommending it for a couple of reasons. One, it's not what the manufacturer calls out and the kinematic viscosity is all wrong. Second, there are additives, friction modifiers and detergents in even generic Dex-III that 80w-90 GLI 4/5 doesn't have. I'm not calling you stupid (because maybe you know something I don't), but I am calling you brave! ;)
  3. Jun 18, 2013 at 11:07 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    You my friend just fawked up your transmission. Why on earth would you add gear oil to an automatic? Unless your drunk.
  4. Jun 18, 2013 at 11:22 PM
    4x4yota
    4x4yota 4wd is awesome
    Collin
    PA
    02 trd stepside v6
    80w-90 is SO much thicker than atf fluid. I wouldnt think it would be a good idea. But like the other guys said maybe u know something we dont so this is an occasion for popcorn
    :popcorn:
  5. Jun 19, 2013 at 12:03 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I would ask this on bobtheoilguy forum (google it). From my understanding its bad, you should probably flush the thing (via the radiator atf cooling system). Search diy atf flush.
  6. Jun 19, 2013 at 11:50 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    The same reason you'd put ATF in your coolant *cough Krazie cough*
    You sure the people running 80-90 had AUTO transmissions? Cause that's about what the 5-speed MANUAL calls for (I think I put 75-90 in mine, not sure)
  7. Jun 19, 2013 at 2:19 PM
    ARB1977
    North Texas
    Go back and read his question.
  8. Jun 20, 2013 at 7:54 AM
    MowTaco
    Kansas
