auto trans rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Dec 8, 2010.
  1. Dec 8, 2010 at 8:37 AM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    if you were to rebuild an auto trans 05+ model prerunner 2wd.
    Is there performance parts to replace the stock parts with? stronger stuff for towing.
    thanks
  2. Dec 8, 2010 at 8:38 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
  3. Dec 8, 2010 at 12:19 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Supercharger.
  4. Dec 8, 2010 at 12:20 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    get diff truck......
    tranny rebuild sounds exp.......
    g/l
  5. Dec 8, 2010 at 1:04 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    The V6 has the power, but i think the weak link is going to be the transmission using it to tow often. Most cars/trucks you can replace the parts with beefier stuff, metalic plates or something like that. If I could get a rebuild that would make it much tuffer for towing, i would keep it.............if not, have to go with a full size truck................
  6. Dec 8, 2010 at 1:31 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    The Transmission out of our autos is the same one used in the V8 4.7L. The A750. It's more than beefy for what you'll put it through.
  7. Dec 8, 2010 at 1:42 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    IPT can rebuild it for you, but it is expensive
    Import Performance Transmissions.
    I will be sending them my valve body at some point for the upgrade to help with hi power shifts with the blower
    Justin
