auto trans shift cable failure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squad, Apr 14, 2010.
  1. Apr 14, 2010 at 7:05 PM
    Squad
    Squad [OP] New Member
    Washington
    '09 SR5 V6 4X4
    Last week's adventure
    Day 1--87 rough miles on Saline Valley Road in Death Valley
    Day 2--On the black top, pulled into parking lot, shifted into Park, then...
    1. Trans shift cable came off of shift lever
    2. Reattached cable and took rig to dealer
    3. Dealer could find nothing wrong, no surprise
    4. Has been working fine since
    What's up with the cable/shifter connection? Is this a known issue? Can I trust it to stay connected? Just a fluke?
    TIA--:)
  2. Apr 14, 2010 at 7:27 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    First one I have heard of ???
  3. Apr 14, 2010 at 11:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    x2 , never heard this one before ,
    OZ
  4. Apr 14, 2010 at 11:20 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x3
  5. Apr 15, 2010 at 5:58 AM
    Squad
    Washington
    '09 SR5 V6 4X4
    Thanks for the info. I'll just keep and eye on it.
    -Squad
  6. Apr 15, 2010 at 6:22 AM
    81shark
    81shark Well-Known Member
    annoying. i've had the cable break on cars in the past, but not just pop off.
  7. Nov 9, 2010 at 11:03 AM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Just wanted to bump this..
    I had the shifter cable fall off my 08 a little while back. Went to the store, put it in park and it kept going.. Shifter wasnt doing anything so I had my gf hold the brake while I looked under the truck, the nut and bolt fell off on the linkage. Got it back into drive and took the truck to the dealer, they told me to come back.. I explained i could not put my truck in park (acting dumb), and after 10min of talking they finally understood, and took it back and put a nut/bolt back in it.
    I know I could have done it myself but i wanted to make sure they a report of it happening..
    So next time your changing the oil, you might as well check and make sure the linkage is tight.
  8. Jul 12, 2012 at 5:09 PM
    KingTaco81
    KingTaco81 The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    The same thing just happened to me earlier today, the bolt was there but no nut :-/
  9. Jul 12, 2012 at 5:15 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    this makes me nervous. i have an 08 that has been bullet proof for me, but i also did not buy it new, and have never had this happen.
  10. Jul 12, 2012 at 5:22 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Where exactly is this nut/bolt?
  11. Jul 12, 2012 at 5:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Locktite.
  12. Jul 12, 2012 at 5:29 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You could've just shut off the engine and put on the parking brake, I think.
  13. Jul 12, 2012 at 6:08 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    I know that but I didnt know the problem at the time, if I shut the truck off and didnt find a problem i could fix, the truck wouldnt start back up if it was in gear. Having my gf hold the brake was just a way for me to check under the truck and still be able to drive it if I couldnt fix it..
  14. Jul 13, 2012 at 9:50 AM
    KingTaco81
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    The bolt is at the tip of the linkage cable that bolts up to the shifter. Once You turn the truck off it won't start up again unless it's in park. Since my truck was on the lowest gear I wasn't able to start it up. I had to buy a a locking nut n apply lock tight as well.
  15. May 7, 2021 at 4:36 PM
    Kikig66
    Kikig66 New Member
    Kiki_G
    No. Cal
    07 Tacoma 4wd / Crew cab
    Wow ! This literally just happen to my truck , as I pulled into work it would not reverse nor would it park . Just had to shut off an apply P-brake. Looked up location of shift cable / linkage and sure enough it had fallen off . My question is” Does anyone know the nut size on the bolt that holds cable on linkage?”
