Auto Trans slips going to low
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bernie, Jan 2, 2009.
  1. Jan 2, 2009 at 4:36 AM
    Bernie
    Bernie [OP] Member
    Pa.
    taco access cab TRD sport
    none
    I have a 09 with auto trans. My problem, as I reduce speed to make a turn and after coasting through the turn and accelerate the rpm’s go up to 2300 as if in neutral. After 2 seconds Low gear will kick in. My speed on the turn is about 5 mph and this is not a problem from a stop. Any ideas?
  2. Jan 2, 2009 at 5:51 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Well for starters your going throught the Turn entirely too slow.:D But on a serious not I would try to slow down before the turn and accelerate through the turn. Now I'm not talking about lead footing it through the turn but just keeping a constant amount of torque on the system.
    After reading your post again. I would also probably use my above advice while driving to the Dealer to have them take a look at it. offer to take your mechanic for a ride if your not certain he can duplicate it himself.
  3. Jan 2, 2009 at 6:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have your dealer check the fluid level.
  4. Jan 2, 2009 at 6:35 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Are you a two footed driver? Reason I ask is most newer vehicles will shift improperly if your other foot is resting/touching the brake pedal while trying to accelerate. The ecu/trans c/u look at the brake light switch for open/closed circuit status. You will notice a slight change in idle/exhaust tone during manuevers once you take your foot off the brake pedal without touching the gas.
  5. Jan 2, 2009 at 6:51 AM
    Bernie
    Bernie [OP] Member
    Pa.
    none
    Thanks for your reply. No I don't use the two foot application but I do understand what you are saying. I could be doing 40 or better and before the turn I let up on the accelerator and apply the breaks to slow down and mid way through the turn I start to accelerate and have nothing for a couple seconds. That is when it go up to 2300 rpms and then low kicks in and the rpms drop to 1200-1400 rpms.
  6. Jan 2, 2009 at 7:06 AM
    OU812
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    The 5 speed auto units in our trucks do tend to lock up the torque convertor early on under light throttle loads. But since you do have a new truck I recommend taking it to the dealer to have them check it out. If you search on here you will see that several were not filled to proper capacity from the factory.
    Worse comes to worse, you can always ask to drive another one for comparison while at the dealer.
  7. Jan 2, 2009 at 7:25 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2 on that one!;)
  8. Jan 2, 2009 at 7:27 AM
    Bernie
    Bernie [OP] Member
    Pa.
    none
    Thanks, I'll call them asap
