Auto transmission dipstick location? Really?
Discussion in '1st Gen. Tacomas (1995-2004)' started by EdFlecko, Feb 19, 2016.
  1. Feb 19, 2016 at 3:27 PM
    EdFlecko
    EdFlecko [OP] Well-Known Member
    Ed
    Sacramento, California
    I have a 2WD Tacoma with the 2.4 motor. I'm looking for the location of my auto transmission dipstick and I can't believe where it is? Is it really below the intake runners on the driver side and way down in the engine bay?
    For those of you who have the same motor, how do you pull the dipstick without burning the crap out of your hands?...use a long pair of needle-nose pliers to grab it?
    Also, do we have a post(s) you might recommend (I've searched but didn't find anything) on changing the transmission fluid?
    Thank you!
    Ed
  2. Feb 19, 2016 at 9:25 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Can't help you on the dipstick issue because I have a V6, but as far as changing the fluid goes I highly recommend a flush and new filter. Many guys are against flushing transmissions, but I work in a repair shop and have probably done around 100 flushes in the past 2 years I've worked here and not a single complaint from any customer no matter the mileage on their trans at the time. And believe me, I've seen some pretty dirty, cruddy, nasty shit come out of old high mileage transmissions and when refilled with the new stuff, ran and performed better than ever. Never understood where all the horror stories about tranny flushes stems from, maybe the older flushing machines they used "back in the day" caused issues? Our shop's machine just hooks into the tranny cooler lines on the radiator and pulls the old fluid out and circulates the new stuff in while the car's running. On bigger trucks, we have to manually add a few quarts through the dipstick tube in addition to the machine's job.
    You can also just drain and refill with 3.5 to 4 quarts until the tranny fluid starts to look new like many guys here do, but then you still have the same old dirty filter inside so that new fluid will become contaminated quicker. Again, it's just easy all the way around to go with a flush and new filter, IMHO. Take it for what it's worth and decide, in the end it's all up to you!
  3. Feb 20, 2016 at 12:33 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    for checking just use leather work gloves would be my best solution;):notsure:
    ramonortiz55 likes this.
  4. Feb 20, 2016 at 2:30 PM
    EdFlecko
    Ed
    Hmmm...that sounds like the easiest idea!
    Ed
  5. Feb 20, 2016 at 3:11 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Check it while the motors cold?
  6. Feb 20, 2016 at 3:13 PM
    EdFlecko
    Ed
    You certainly could do that, but unless I'm wrong, the only way to be truly accurate is when the motor's running and the vehicle in park.
    Someone please correct me if that's not correct.
    Ed
  7. Feb 20, 2016 at 3:18 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Should be a "cold" and "warm" reading on dipstick so it doesnt matter
