Auto Transmission Fill Plug Washer Size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by I-Give-Up, Sep 2, 2024.
  1. Sep 2, 2024 at 6:25 PM
    I-Give-Up
    I-Give-Up [OP] Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Anybody know the size or part number of the automatic transmission fill plug washer? It's for a 2023 TRD V6. Is it a crush washer or a copper washer?
    I found the part number for the fill and check plug washers by searching the forum. Those are No. 35178-30010.
  2. Sep 2, 2024 at 6:44 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    @I-Give-Up o-ring. Reused mine because it was on back order at dealer. Figured I could procure one elsewhere if I had to, worked fine using the old one.
    Toyota part # 90301-15004
    I-Give-Up[QUOTED][OP] likes this.
  3. Sep 2, 2024 at 6:52 PM
    Stuck in VT
    Utah
    2019 SR SX MGM
    @I-Give-Up Sticky at the top 3rd gen diy quick maintenance has lots of parts numbers, torque settings fluid types if you have not found that yet. Don't know how to link it to my post.
    I-Give-Up[OP] likes this.
  4. Sep 2, 2024 at 7:00 PM
    I-Give-Up
    West Phoenix, AZ
    I don't know how I missed that. But it is full of stuff. Thanks.
    Stuck in VT[QUOTED] likes this.
  5. Sep 2, 2024 at 7:03 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Fill plug washer is rubber. Mine looked good so I re-used it.
    Check out 1:40 in on this video from the Maintenance Map.
    https://www.youtube.com/watch?v=rNqYpEpmUng
    Stuck in VT likes this.
  6. Sep 2, 2024 at 7:08 PM
    Stuck in VT
    Utah
    2019 SR SX MGM
    Really helpful concise video.
  7. Sep 5, 2024 at 9:43 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I am unclear on the gasket/washer used specifically for the overflow plug.
    The video mentioned a crush washer under the 5mm hex plug.
    Anybody know for certain?
  8. Sep 5, 2024 at 10:06 AM
    TA2016
    Oregon
    I just did a drain and fill. My rubber gasket on my fill plug looked good so I reused it. I put a new crush washer on the Hex check plug and a new crush washer on the drain plug.
  9. Sep 5, 2024 at 10:17 AM
    bgavin
    Orangevale, CA
  10. Sep 5, 2024 at 11:19 AM
    Stuck in VT
    Utah
    2019 SR SX MGM
  11. Sep 8, 2024 at 8:21 AM
    DarinL
    DarinL Well-Known Member
    Darin
    2017 Tacoma 4x4 TRD 4-dr longbox
    O-ring OEM substitute - McMaster-Carr's website, part number 5233T674 is a silicone O-ring with dimensions 16mm x 21mm x 2.5mm (IDxODxwide). Pack of 25 is ~$15USD. The temp range is -60C (-80F) to +232C (450F) so well beyond trans temp range and trans fluid won't eat silicone. The OEM Toyota O-rings are notoriously hard to find. Dealerships are continuously out of stock (yet somehow have no trouble booking appointments for transmission service (either reusing O-rings or hoarding their own supply - who knows). Compounding that, it's like Amazon can't recognize the specific Toyota part number 90301-15004 either. Hope this helps folks.
  12. Sep 8, 2024 at 8:31 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I-Give-Up[QUOTED][OP] and bgavin like this.
  13. Sep 8, 2024 at 11:16 AM
    I-Give-Up
    West Phoenix, AZ
    For the fill plug, I wonder if a size-appropriate nitrile or green air conditioning O ring would do in the absence of the "correct" part. The air conditioning O rings are amazingly tough and oil resistant.
    I have a large stock of these, plus a selection of copper washers.
  14. Sep 8, 2024 at 11:21 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    C’mon. Are things that bad you can’t afford the 0.50 on OEM and then spending $500 to fix a situation from a bad decision? Oy vey!
  15. Sep 8, 2024 at 11:22 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    I have a new one if you need one. Send me PM and I’ll send you one for free. The stamp will cost more than the washer.
  16. Sep 9, 2024 at 5:35 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    Why not reuse the o-ring?
  17. Sep 9, 2024 at 6:05 AM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    I asked about it at the dealership, and they said they'd have to order one from Japan if I wanted one. I reused it, but if it were damaged I'd just find a similar one in the parts bins at the hardware store.
