Auto transmission mini fill/drain every 3k...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokarl, Apr 16, 2023.
  1. Apr 16, 2023 at 11:53 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yeah. I’ll say it again.
    OP can do what ever he wants.
    And I don’t abide by industry standards, especially when I have no idea what industry standard to go by? Aisin maybe?
    Naveronski likes this.
  2. Apr 16, 2023 at 12:27 PM
    Firn
    Firn Well-Known Member
    White OR
    If you could quote where I said this is the industry standard for light vehicles I would appreciate it.
    AGAIN, in INDUSTRY partial drop and replace is normal, and those practice can ALSO BE APPLIED HERE.
    So drop and fill the WHOLE THING every 60,000 miles, or drop and fill a PORTION regularly. The end effect is the same.
    I can never tell if folks really can't understand these topics or are purposely being obtuse.
    JGO likes this.
  3. Apr 16, 2023 at 12:33 PM
    TnShooter
    Deogee
    STOCK
    If those are my choices, I’m going with drop and fill every 60k, before I drain and fill every 3k. If I have to drain and fill every 3k, then I need a different truck.
    Anyone else can do how they please.
    Their time, their money.
    The best advice I can give is go by what Toyota and Aisin set forth in the manual.
    I don’t know exactly what the manual says, I don’t go by the manual exactly.
  4. Apr 16, 2023 at 12:36 PM
    Firn
    White OR
    My god, do you not understand it is the same thing? Replace a little bit over time or replace the whole thing in one shot.
    Then you say make sure to follow the manual, but don't follow the manual.
    Why am I not surprised around here
  5. Apr 16, 2023 at 12:55 PM
    TnShooter
    Deogee
    STOCK
    No. I said the best advice is to go by the manual. I also said I don’t go by the manual. What I do, and what you should do, are two different things.
    What I think you don’t understand is, I never told OP what to do. I stated what I wouldn’t do. I also think you don’t understand that I don’t care about industry standards.
    To make this more understandable, I will say the following
    1. I don’t care about industry standards.
    2. I am not changing transmission fluid at 3,000 miles. Not a little bit, not a whole lot. None. I’m not changing anything.
    3. If I have change fluid at 3,000, than I don’t want it.
    4. I will agree ( yeah, I said it)
    Exchanging a little fluid every 3k is marginally better than changing all the fluid at 60k.
    5. If the transmission can’t run on “a little worse” fluid, it’s not for me. We’re back to #3.
    6. Lastly, I’m not concerned at all about the state of the fluid in 3k increments. I’ll go based off how I use the truck/transmission.
  6. Apr 16, 2023 at 1:03 PM
    Firn
    White OR
    Holy shit.
    Nobody told you what YOU had to do.
    Nobody said this is what anyone SHOULD do.
    The OP was asking if it's OK if HE does this. And you decided to argue the shit out of it.
    JGO and TnShooter[QUOTED] like this.
  7. Apr 16, 2023 at 1:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Similar experience. I started driving in 1973. I've never changed the ATF on any vehicle I've ever owned. The only transmission issues I've had were electrical. I have over 1/2 million combined miles sitting on the driveway with the factory transmission fluid in all of them. Almost 1/2 of that on my 07 Tacoma. They all drive just like the day they were bought.
    If you do a service every 30,000 miles you'll actually end up spending more on servicing the transmission than it would cost to have it rebuilt. And you'll still have to pay to have it rebuilt at about the same point.
    Blockhead and Naveronski like this.
  8. Apr 16, 2023 at 1:18 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    You’re getting awfully upset about unnecessary maintenance.
    In which industry?
    b_r_o, Taco-Grinder and TnShooter like this.
  9. Apr 16, 2023 at 1:27 PM
    TnShooter
    Deogee
    STOCK
    Yeah. Pretty much.
    I never said what anyone should do.
    No one said what I should do.
    I said what I wouldn’t do.
    I also said more than once, op can do what ever he wants.
    Somewhere in there I said, “it can’t hurt it”.
    I ain’t arguing. I am repeatedly saying the same thing over and over. :rofl:
    I’ll quit saying it eventually. But I am not quite burnt out just yet.
    It’s still a bit comical to me at the moment.
    Williston likes this.
  10. Apr 16, 2023 at 1:52 PM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Is this an episode of dumb and dumber??
    TnShooter likes this.
  11. Apr 16, 2023 at 1:53 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yes to everything you said. Sounds crazy check, quick easy simple check, overkill check, but hey you do you . Want I can say is 5 Toyotas in myself , 60k fluid changes all ran fine still with 400k miles on them.
  12. Apr 16, 2023 at 3:38 PM
    tacokarl
    tacokarl [OP] Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Thank you!
    As stated in my OP I'm not talking about a drain in fill, in fact I should have titled this thread FILL/CHECK as the drain plug would never be removed. I'm talking about slightly over filling the tranny by half to 1 qt and then going through the temp check procedure draining the excess fluid from the check port.
    Also, some of you guys need to chill. I literally said in the first sentence I acknowledge how crazy this may sound. The entire point of this website existing is to ask questions, discuss topics, and share ideas and information. I can guarantee some of you do things and treat your truck how I never and vice versa. Nobody's wrong, nobody's right. Stop caring so much.
  13. Apr 17, 2023 at 9:35 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    JGO and Friend of Crows like this.
  14. Apr 17, 2023 at 1:14 PM
    Friend of Crows
    2022 Tacoma SR
    That Toyota guy is fantastic...
  15. Apr 18, 2023 at 5:23 AM
    #35
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    You’ve been a member here long enough to know that fluid changes of any kind can be a controversial topic with differing opinions. Nobody needs to ‘chill’ …
    TnShooter and Naveronski like this.
  16. Apr 18, 2023 at 5:30 AM
    #36
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I think 50% of the time, it’s on purpose. The other 50% is just stupidity.
    Firn[QUOTED] likes this.
  17. Apr 18, 2023 at 5:46 AM
    #37
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    I'll play along.
    OP, do as you please, whatever might give you the tinglies and satisfaction. I do annual drain and fills, so usually it's about 10K-13K miles in between. Overkill? Perhaps. My truck also has 325K on it and I plan to keep it for as long as I can. So again, do as you please. I will say, 3K might be overkill, but if you're changing your engine oil at the same time and enjoy knocking out both at the same time, then I can understand where you're coming from, so I don't fault you there. Take it for what it's worth.
  18. Apr 18, 2023 at 5:54 AM
    #38
    deaps
    deaps Well-Known Member
    2023 TRD OR
    I think this really depends on where in the fluid the majority of particulate matter accumulates. That's to say if it "floats" and you are draining off the top inch, then you're doing a good thing, or conversely, if it sinks, and you are draining out the bottom inch, then that's good. If it's equally suspended throughout, you're essentially following the principle of "dilution is the solution to pollution," which isn't a bad thing necessarily. If any of the above isn't true, it may be all for naught. Especially considering you'd eventually want to replace the filter, right? Where, by design, the majority of the particulate matter definitely does accumulate.
    PS...starting an open topic, then telling people who bring data or experiences into that conversation by participating, to chill...is a bit weird, to say the least.
    Off Topic Guy likes this.
  19. Apr 18, 2023 at 6:04 AM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Careful with those drain plug threads. That little plug really isn't designed to be removed and retightened that much. Heck there's only like 5 threads in the pan side. But whatever floats your boat
    I've done one spill and fill in 160,000 miles
    These trucks aren't that brittle, I don't see what exactly is being gained by doing it so frequently
  20. Apr 18, 2023 at 6:42 AM
    #40
    Firn
    White OR
    All it is doing is instead of every 60,000 miles doing a complete change of fluid you are just doing a small portion of fluid every 3,000 miles (or every oil change). Its the same thing but instead of changing all fluid at once you change all the fluid a little bit at a time.
    Just two methods to try and achieve the same goal, OP just figures that since he is already under there doing maintenance just add a little bit of time and do some to the transmission as well instead of doing it as one big service at a different time.
