Auto Transmission shift lock solenoid clicks with CEL
Discussion in 'Technical Chat' started by Bo_04_taco_TRD Prerunner, Apr 11, 2021.
  1. Apr 11, 2021 at 7:32 AM
    Bo_04_taco_TRD Prerunner [OP] Member
    2004 Gold Tacoma TRD Prerunner
    Fox 2.0 res and coils front. LED lights, K&N cold air, Engine chip performance, roof rack
    Okay guys, so my truck was doing just fine and then it just died on me while accelerating. The CEL came on and is flashing very quickly. I noticed a clicking noise in conjunction with the CEL on top of the tranny so I took a look and found it coming from the shift lock solenoid. Key on and brake pressed, the gears shift fine. The truck will turn over but will not fire off. I’m thinking computer or ignition issue. Any ideas out there? I feel like the solenoid clicking is a symptom, but of what idk.
  2. Apr 11, 2021 at 7:41 AM
    gearcruncher
    Canadain bumper technician
    Sounds like a loss of voltage from loose wiring .
    Check all your grounds , check the battery terminals .
  3. Apr 12, 2021 at 9:24 AM
    Thanks Gearcruncher. I had replaced the valve cover gaskets and the Air Plenum gaskets about 6-8 months ago. So, I looked around there and found there was a ground cable loose that mounts to the lower manifold. Keep in mind, I had the ground removed from the battery for trouble shooting on the ECU. When I put it back together, including unplugging and re-plugging my ECU behind the glove box back in, the truck started. I have not road tested it yet, but the caution light is out for now. I will keep you updated.
