Auto Transmission Stuck in 4th Gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MagTaco, Feb 12, 2016.
  1. Feb 12, 2016 at 9:11 AM
    MagTaco
    MagTaco [OP] Well-Known Member
    Jeff
    2016 Magnetic Grey Tacoma TRD OR
    2016 OR DC gets stuck in 4th gear under load especially on an incline.
    1/29/16 @2k miles Dealer serviced for low fluid in the transmission and added 1.5 qts.
    After fluid was added the truck noticeably shifted nicer however it still would get stuck in 4th gear on an incline.
    2/10/16 @3k miles Dealer serviced for "getting stuck in 4th" and opened a case with Toyota. Toyota tech support recommended re-flashing the ECU and performing a hard reset on the truck. Tech at the dealer believes the truck needs a software update for the transmission. They advised me to drive it and see if it made a difference. No difference was made except now it seems the transmission is "relearning"
    Is anyone else having this problem? Truck only gets stuck in 4th on an incline, Warm or Cold it doesn't matter it happens. I was even able to catch it on video.
    Hoping the truck just needs a software update and that it was not damaged from driving 2k miles on 1.5 qt low of tranny fluid....
    Here's the video, Notice when I remove my foot from the gas pedal the truck stays pinged above 2k RPM's...
  2. Feb 12, 2016 at 9:28 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    maybe a dumb question, but how do you definitively know what gear you are in? (I assume you have an auto tran)
    kahanabob likes this.
  3. Feb 12, 2016 at 9:29 AM
    MagTaco
    Jeff
    When I accelerated from a stop assuming I was in first I felt the truck shift to 2nd then 3rd then 4th.
    You're correct though I am assuming I am in 4th.
    kahanabob and vuTron[QUOTED] like this.
  4. Feb 12, 2016 at 9:43 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    My 2gen does this type of thing sometimes. There's a certain section of road on my daily commute that I can make it happen every time.
    It seems to happen the most for me when it downshifts up an incline and I never let off the gas even once the road transitions to a decline. I can also get it to not want to shift in another situation. if I tap the brake going downhill, it will downshift for engine braking. But once I get back on the gas, it refuses to upshift. It's always done it, so I never questioned it. This is also the first Auto I've driven in about 15 years.
    Try bumping the shifter from 'D' to '4' and then back to 'D' again. That should make it upshift. I'm not sure the "problem". It seems Toyota transmissions just have weird shifting logic.
  5. Feb 12, 2016 at 9:47 AM
    MagTaco
    Jeff
    Hmmm... You could be correct... It wouldn't bother me at all if I didn't know the truck was 1.5qts low on tranny fluid.. Maybe it's all mental to me. But like you said this certain section of road I can make the truck do it EVERY time. Just seems odd it wont shift letting off the gas and even touching the brake pedal...
    bkw likes this.
  6. Feb 12, 2016 at 10:00 AM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    OP mine does the SAME thing. There are other threads on this, but here's the kicker ....
    TAKE IT OFF CRUISE!
    Yup, I was getting average 15 mpg.
    I have a TRD OR AUTO
    Someone told me DON'T use the cruise.
    The Taco needs a software ECU or PCM update.
    I very rarely use the cruise now ... unless completely flat and NO WIND.
    I paid $45K for mine with all warranties.
    You would think the cruise would work better.
    The cruise keeps the speed constant, but the 3.5 engine doesn't have enough power to maintain that speed in high gear so it downshifts and won't shift up until you go down a hill.
    Posted speeds on our interstates are 75, 80 & 85 mph.
    You can see mine stuck in 4th gear too.
  7. Feb 12, 2016 at 10:06 AM
    MagTaco
    Jeff
    But I'm not on cruise control... That's the problem. The two green lights you see in the video are the headlights and fog light emblems.
    SamChieftan[QUOTED] likes this.
  8. Feb 12, 2016 at 10:32 AM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    If you are going 40mph on a dead flat road with no wind, it stays in 4th gear?
  9. Feb 12, 2016 at 10:36 AM
    MagTaco
    Jeff
    No, It only has an extended shift with a steady foot on the pedal under a load. Going up hill usually will cause this problem. Down hill or a flat road It will not occur.
  10. Feb 12, 2016 at 10:39 AM
    MagTaco
    Jeff
    If you watch the video posted above you'll see the truck stays in 4th even when the road levels out. It does not up shift until the road begins to decline.
  11. Feb 12, 2016 at 10:41 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like a TCC solenoid problem.
  12. Feb 12, 2016 at 10:44 AM
    MagTaco
    Jeff
    Thats what @gearcruncher Suggested in another thread I believe... Wouldn't this signal an error code? Dealer stated no codes were listed.
  13. Feb 12, 2016 at 10:45 AM
    swimmer
    Tucson
    2016 TRDORAC4WD
    You didn't answer my question. Anyway, at the end of the video at 53mph it looks like it goes into 6th gear. So, the title of your thread is misleading. Your truck is not stuck in 4th gear. Your truck, for you, is reluctant to stay/shift into a higher gear.
  14. Feb 12, 2016 at 10:47 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    The rubber o ring around the solenoid sticks in the bore and won't allow it to move (until it does) A person "could" remove the solenoid and lube it with some trans fluid to free it up but ya that should not be something you have to do.
  15. Feb 12, 2016 at 10:49 AM
    MagTaco
    Jeff
    I agree, I'll suggest this to the dealer when I return to have the hood fixed... Thanks for the heads up.
  16. Feb 12, 2016 at 10:52 AM
    MagTaco
    Jeff
    :notsure: As mentioned earlier.... I was assuming I was stuck in 4th. Its an assumption. If it were a manual transmission I could provide you with an accurate title and accurate gear selection...
  17. Feb 12, 2016 at 10:57 AM
    swimmer
    Tucson
    2016 TRDORAC4WD
    But your truck clearly goes into 5th or 6th gear (seems like 6 to me)at the end of the video so it isn't stuck in any gear.
  18. Feb 12, 2016 at 11:01 AM
    MagTaco
    Jeff
    It's clearly not supposed to hold whatever gear it is in at 3k RPM's... Even when the road flattens out I tap the gas and it still does not shift. The truck does not shift until the road begins to decline.
  19. Feb 12, 2016 at 11:23 AM
    swimmer
    Tucson
    2016 TRDORAC4WD
    Provided your truck is totally stock, I agree. It's still not stuck in a gear. I would give some time after the reset the dealer did and hopefully it gets better.
  20. Feb 12, 2016 at 4:00 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    think the green thingy left of the word SET is cruise control?
