auto vs manual
Discussion in '4 Cylinder' started by xcheese1, May 17, 2012.
  1. May 17, 2012 at 1:00 PM
    xcheese1
    xcheese1 [OP] Kobe
    joe rogan
    CA
    Access Cab 4x4
    so i know there is all of this talk about how the auto i4 2nd gen is more sluggish than the manual but does anybody have anything to back this up? 0-60 times or even a video accelerating from standstill. i just had a friend with a prerunner i4 manual say that my 4x4 access cab auto seemed faster...
  2. May 17, 2012 at 1:06 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Couldn't you drive both? Are they similar years/body etc?
  3. May 17, 2012 at 1:50 PM
    xcheese1
    xcheese1 [OP] Kobe
    joe rogan
    CA
    Access Cab 4x4
    no unfortunately he lives out of state and was just visiting. though it would be an interesting thread for everybody too. i definitely want to though!
  4. May 17, 2012 at 1:53 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    General consensus is that the lack of "power" from the AT is that it inconveniently decides when to shift, with the MT you can control when to shift at low rpms for daily driving and when the higher are advantageous (passing, etc). It's not that either is faster, better, has more horses engine wise.
  5. May 17, 2012 at 2:41 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I drive a Manual 2nd Gen. Off of the line it is anything but quick. If you are lookin for somethin sporty, you will want to consider somethin else.
  6. May 17, 2012 at 4:13 PM
    The Shape
    The Shape Well-Known Member
    Forrest City, AR
    '09 Access Cab A/T 4banger
    I have driven both, neither are what you would call quick.
  7. May 17, 2012 at 5:54 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    I have the double cab auto, and I recorded a 0-60 (up a slight hill) at 13.7 seconds
  8. May 18, 2012 at 4:15 AM
    The Shape
    Forrest City, AR
    It comes down to what you want to do with the vehicle. I have owned several V8/manual cars that were quick (for street cars). But when I bought this Tacoma I wanted a reliable light truck that was decent on gas and wouldn't require much wrenching or maintainence for a long time and it fits that bill perfectly. Quick wasn't what I Was looking for.
  9. May 18, 2012 at 6:01 AM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Just how, exactly, does your comment help the discussion?
  10. May 18, 2012 at 6:08 AM
    Wyowill
    Wyowill Active Member
    I have an '05 base model 4x4 manual, neighbor has an '05 base model 4x2 auto. Both stock. Manual is MUCH snappier
  11. May 18, 2012 at 6:27 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    The real answer is the torque converter. When unlocked, a torque converter will rob you of power. On these transmissions, I believe that the torque converter will only lock up in 4th at cruising throttle. Maybe 3rd, not certain.
    The other issue involves the available gear ratios;
    Automatic: 2.804, 1.531, 1.000, 0.705
    Manual: 3.954, 2.062, 1.436, 1.000, 0.805
    You will note the massive difference in the 1st gear ratio.
    Now as far as the 'seat of the pants' feel goes, a very low first gear ratio can actually slow you down. If you look at the first gear ratio of a performance car, it will probably more closely resemble the automatic.
    On the manual, 1st gear will get you rolling, second will rocket you to 90kph/55mph, and 3rd will run you as fast as you could practically ever want to go. On the automatic, you will get more substantial acceleration while still in first to about 60kph/37.5mph, then you've got 2nd from there to highway speed.
    On the manual, for passing, you get your choice of 1.436 or 1.000. With the automatic, you have 1.531 and1.000.
    Now the tradeoff here, is that the manual will be slower to get rolling, but better off once it is.
    On top of that, you have to consider the effects of carrying a payload. The manual, though possibly slower at the low end, has 41% higher take-off torque. That means that when you're under load, it has the clear advantage.
    Finally, look at the issue of heat. The torque destroyer (aka converter), destroys torque by converting it into heat. Heat makes things break.
    Fast1 likes this.
  12. May 18, 2012 at 6:28 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Don't forget that he has different axle ratio than you....
  13. May 18, 2012 at 6:44 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    That would be a matter of perspective. Again though, you aren't adding to this thread.
    You really should look into that a bit more. 4.1 ratio only applies to prerunner/4x4. The base model 4x2's have either 3.307 (MT) or 3.583 (AT).
  14. May 18, 2012 at 6:59 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Look, pal... you don't even HAVE a 4-cyl, so your opinions are meaningless with respect to them. What I am suggesting is simply that if you don't have anything useful to add, then don't bother adding anything. Especially don't add incorrect information -- that doesn't help anyone.
    Your lack of knowledge is reason enough for you not to be here. Ther is nothing new about these ratios, they have been used in base model 4 cyls since 2005. Nothing has changed. You're welcome not to believe me, but before you say anything hasty, go over to toyota.com and have a look at the axle ratios. They're listed under specifications/dimensions at the bottom.
  15. May 18, 2012 at 7:12 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Why you
  16. May 18, 2012 at 7:39 AM
    knucklehead
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    I take that back, you obviously do have a 4-cyl....
  17. May 18, 2012 at 7:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Okay kids- If we are trying to keep a thread on topic- Then flinging insults isn't helping.
    Let's everyone walk away and realize the internet isn't this serious....
  18. May 18, 2012 at 8:02 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Didn't dhk have a 4 banger from Ontario ?
  19. May 18, 2012 at 8:07 AM
    OZ-T
    Peter North
    British Columbia
    Awesome
  20. May 18, 2012 at 8:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    He is correct. The 5 luggers have 2 different rear diff gears, depending on tranny. THe 6 lugs get 4.10's for the 2.7, and 3.73's for the 6.
