AutoAnything.com Group Buys and Discounts (I am no longer working here)
Discussion in 'Deals & Coupons' started by eccracer104, Jun 20, 2017.
Thread Status:
Not open for further replies.
  1. Oct 21, 2017 at 2:21 AM
    #301
    JPOVS
    JPOVS New Member
    Josh
    2016 4Runner Trail
    Any discount on the ARB 2500 awning?
    eccracer104[OP] likes this.
  2. Oct 21, 2017 at 3:06 AM
    #302
    StainlessSteelRatt
    StainlessSteelRatt Well-Known Member
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Icon, SPC, OME Dakar, Mobtown
  3. Oct 23, 2017 at 2:40 PM
    #303
    eccracer104
    eccracer104 [OP] O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Yep! PM inbound :thumbsup:
  4. Oct 23, 2017 at 2:44 PM
    #304
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    :wave:
  5. Oct 23, 2017 at 3:35 PM
    #305
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    I gotta say, Autoanything's customer service is great.
    I got my Extang Encore Tonneau cover here; I managed to strip one of the clamps and they sent me a new one right away.
    I'm this close to buying Icon Stage 2's here too... :D
  6. Oct 23, 2017 at 3:44 PM
    #306
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    :woot: That's always good to hear! The management here has done a great job hiring really genuine people and filtering out the bad apples.
    I'm familiar with Icon if you have any questions :cool:
  7. Oct 23, 2017 at 4:41 PM
    #307
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
  8. Oct 23, 2017 at 9:56 PM
    #308
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    So, I'm looking at Icon Stage 2 for a 2016 Tacoma TRDOR (DCSB).
    How rough is the installation? I'm only handy-ish (handy capable?), but I did manage to install my Mobtown sliders and my tonneau cover without killing myself. I don't mind buying more tools if this is something your average bonehead can do.
    In the instructions to install the rear shocks, it says to sand the shock mount? I'm not sure how this should be done. If I put these in myself I want to do it right, if I had a shop do it for me I'd want to know what to check for to make sure they did it right.
    The rest actually looks pretty straightforward.
  9. Oct 24, 2017 at 8:15 AM
    #309
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    They say to sand the shock mounts? I'll need to read those instructions then haha. I have fox 2.0 in the rear that I got in a "kit" when I ordered my All Pro Std rear leaf springs, I only have Icon up front. My rear shocks were a direct fit, no sanding required.
    **** I Looked it up ****
    I don't think "sanding" was the best verbiage here, more like cut or grind off a part of the bucket. You essentially need to notch it to accommodate room for the resi hose. If you don't cut this notch you will more than likely create a leak, I remember reading it in a thread on here.
    The front installation is very straight forward for the C/O. Your stock front assemblies are 3 nuts on the top and the one large bolt at the bottom. If memory serves correct the top nuts are a 14mm and the bottom bolt is a 19mm. That bottom guy can be tight so have a breaker bar or an impact driver to take it off. I can't recall the torque specs for re-installation but if you don't have a torque wrench I'd recommend getting one. Disconnecting the sway bar end link may be needed to help droop the suspension further as well. Sometimes the complete assemblies can be a pain to wiggle and maneuver out between the UCA, LCA, spindle and sway bar.
    I would recommend jumping up to the stage 3 to get the UCAs as well. Those UCAs are a bit tedious to install on a 3rd gen since you need to cut the UCA through bolt off and then install the new bolt the opposite direction. They do however improve your range of travel and allow you to have a solid 2.5" of lift while retaining the correct alignment specs.
    I've never personally installed an AAL however I've heard it's quite simple. Looking over the instructions it does appear to be an easy installation. Separating the axle and the leaf springs for the first time can be pretty intimidating but it's really not too bad. You're working with heavy parts that do have tension on them, so please think about what you're doing twice before proceeding forward with anything. Also do one side at a time to help keep the axle centered and to have a reference point if you need to check what the other side looks like.
    Also if you don't already have them get some quality 6 ton jacks, the big guys. The smaller jacks weight wise will do, but they aren't always tall enough. The 6 ton jacks are quite a bit taller.
    ^ Hopefully that all makes sense, I'd happily clear something up if it doesn't. Being your first time really getting in there and wrenching on some major components recruit some friends more mechanically inclined or better yet some local members! People are usually motivated to work for pizza and beer.
    Another question, Are you familiar with how Icon suspension feels and rides? Some love it, some hate it. I can also get my hands on Fox and King and can still piece together a "kit" by pairing it with the Icon UCAs and AAL. I ask because I am very happy with my Icon C/Os but... IMO King feels better. Their progressive valving has a different ride characteristic at slower speeds vs Icon's digressive valving which does ride like butter when moving more quickly but can be a bit harsh at slow speeds.
    Sorry, long post, there's so much to talk about when it comes to high end suspension!
    - Mike
  10. Oct 24, 2017 at 3:44 PM
    #310
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
    Interested in some stage 1 icon Shocks
  11. Oct 26, 2017 at 1:32 PM
    #311
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Our TW friend @Dessertjunkie858 is in a contest to win a free recording session, if you all could please watch and give her a thumbs up it would be greatly appreciated! :cheers:
    https://www.youtube.com/watch?v=TGtJ1dZ7yB8&index=13&list=PLTsKR0r6tU4AbZD5kY0pESx1GOj3uw0KR
  12. Oct 28, 2017 at 8:20 PM
    #312
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @eccracer104
    Any discounts on a set of Bushwacker fender flares for a 2017?
  13. Oct 30, 2017 at 8:14 AM
    #313
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    I'll see what I can do, PM headed your way!
    M1Awolf[QUOTED] likes this.
  14. Oct 30, 2017 at 8:47 AM
    #314
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2000 tacoma 2000 4runner
    Toytec lift,4xinnovations bumper
    ANY arb sales coming up?
    fatfurious2 and eccracer104[OP] like this.
  15. Oct 30, 2017 at 8:51 AM
    #315
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Switchpro discount?
  16. Oct 30, 2017 at 9:06 AM
    #316
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    :notsure: Maybe. Lol. I wish I had an answer for you, but the team that sets the pricing and sales doesn't let us know ahead of time when things are going on sale.
    AutoAnything no longer offers Switch Pros, I'm not quite sure why it's still shown online but it should be removed soon.
    SoJersey[QUOTED] likes this.
  17. Oct 30, 2017 at 9:11 AM
    #317
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    09 TRD Offroad 4x4 - MGM
    Plethora of "useless" shit
  18. Oct 30, 2017 at 9:29 AM
    #318
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Oh wow that one sounds badass! The color picker is neat, but the higher amperage ability sounds really promising. Color coded wires will be nice too.
    My work dropped the entire brand :pout: Someone much higher up in the food chain than me decided we weren't making enough money with their products so they removed them. I even had an open order for a forum member for one during this which was cancelled (I still feel bad about that).
  19. Oct 30, 2017 at 11:42 AM
    #319
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @eccracer104 what is up with FALL22 working on ARB awning walls, but not the awning itself? I would buy if it worked on the awning
  20. Oct 30, 2017 at 12:39 PM
    #320
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    It used too, I think I used it on too many awnings for members and someone figured it out and put a stop to it :bananadead:
    Which awning are you looking at? I'll see what I can do!
    fatfurious2[QUOTED] likes this.
Thread Status:
