AutoLSD experience uphill backwards on gravel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner11, Jun 25, 2013.
  1. Jun 25, 2013 at 4:42 PM
    prerunner11
    prerunner11 [OP] Well-Known Member
    MD
    2011 Magnetic Grey Prerunner Dbl Cab Sport
    Softopper
    I finally got a chance to use my autoLSD on my truck. Unfortunately it wasn't the best experience.
    I was backing up a gravel/wet dirt packed incline in my truck. My bed was basically empty. I was in reverse and slowly started backing up. Then I realized I wasn't moving anymore, so I pressed on the gas. Still no movement but I saw the trac light coming on.
    I hit he button to turn on autoLSD and tried again. At this point I heard rocks getting hit off the wall but still no movement. So I got out to look and saw one back tire had dug in about 4 inches and was in wet dirt and the other tire had barely dug up.
    Now I wish I would have gotten out before I hit the autoLSD button. But maybe I wasn't hitting the gas enough. I didn't want to keep pelting rocks off the wall.
    I was able to put it in drive down the hill and back up again with more momentum and a slightly different path with success.
    Any similar experiences?
  2. Jun 25, 2013 at 4:50 PM
    Raoul Duke
    Raoul Duke Well-Known Member
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    retrofit/bhlm, CB, System, color match grill, debadge, TRD wheels
    Buying a locker to back up a driveway might be a little pricy, your one tire was probably too deep for your autoLSD to help you. It may have worked if you had it on for your first attempt.
    I'm surprised that you have auto LSD but no locker, I thought that all non locker tacomas had a mechanical LSD
    Or putting it into 4wd would have worked
  3. Jun 25, 2013 at 4:56 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OP has a Sport Prerunner
    No locker
    No 4wd
  4. Jun 25, 2013 at 4:59 PM
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    Oh shit hahaha I always forget about prerunners!!
  5. Jun 25, 2013 at 5:01 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    So your saying the hood scoop was no help? :eek:
  6. Jun 25, 2013 at 5:03 PM
    OZ-T
    Peter North
    British Columbia
    Not in reverse duh
  7. Jun 25, 2013 at 5:10 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    No experience yet with the ALSD. I've always wondered what situations I should be using it. Haven't needed it yet.
    Question to all: When would be the proper time to engage ALSD? Launching a boat?
  8. Jun 25, 2013 at 5:19 PM
    prerunner11
    MD
    Softopper
    Not true. I've heard guys use it when 4wd wouldn't engage and it got them unstuck.
    Leave the scoop and prerunner jokes outta here. That's not the intent of this thread.
  9. Jun 25, 2013 at 5:44 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    The 2nd paragraph wasn't referring to you, just the 1st. Read the post a little further up.
  10. Jun 25, 2013 at 5:45 PM
    prerunner11
    MD
    Softopper
    The hood scoop and prerunner comment was not aimed at you. Just in general to others making the comments.
    Obviously autoLSD didn't help me here, but maybe I was using it wrong or not a good situation for it.
    No idea with reference to boat ramps.
    I'll add more pics when my connection doesn't suck.
  11. Jun 25, 2013 at 6:04 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Maybe your bumper was dragging a bit. Reverse is a good way to get up a hill in adverse conditions in 2WD, for some reason it generally works better than trying to go forward.
    Auto-LSD is a braking function, it tries to brake the spinning wheel with the ABS system. From my understanding it isn't instantly responsive, though. You have to get the RPM's up for it to engage. Hence you couldn't just grind your way out of gravel, you'd have to stomp on the skinny pedal pretty good.
  12. Jun 25, 2013 at 6:11 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Good to see you have a sense of humor :rolleyes:
    I've got the same truck as you just no scoop so can I have yours since you don't need it? :)
    __________________
  13. Jun 25, 2013 at 7:52 PM
    Puppypolice78
    Puppypolice78 Active Member
    NC
    4X4 2.7L
    Lol... On a serious note, I've tried using Auto LSD in reverse and it never seems to do much of anything. It does make me wonder if it even functions in reverse? The manual doesn't seem to address this.
  14. Jun 25, 2013 at 8:43 PM
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    Haha. To both comments ;)
  15. Jun 26, 2013 at 11:53 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    heehee this is funny, its like high school and people get all huffy because they don't have the fancy shoes that other people have and get all nuts about it.
