Automatic 5 speed, ever try to use forth gear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10silvertaco, Sep 2, 2009.
  1. Sep 2, 2009 at 1:45 PM
    10silvertaco
    10silvertaco [OP] Well-Known Member
    Brent
    no longer own Tacoma, now own 2011 Outback
    Hey there,
    I was driving up the moutain last weekend. Some of driving up the hills. I didn't bother to use fourth gear. My friend told me it will be better to use it before overheating. He doesn't have pickup truck, just regular front wheel drive. Let me know.
  2. Sep 2, 2009 at 1:47 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I use 4th just to limit some of the additional shifting, also it is a little more peppy :D
  3. Sep 2, 2009 at 1:48 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    4th is fine. Your engine will be working harder in a higher gear trying to go uphill. Your friend is on crack. Lol JK
    Kind Regards,
  4. Sep 2, 2009 at 1:53 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    I too use 4th to go up hills in the mtns. Is there a speed that I shouldn't go over while in 4th though?
  5. Sep 2, 2009 at 2:02 PM
    Jester243
    Dan
    Spokane, WA
    You can go as fast as you want (within legal limits :devil:) if you want, you just pull higher RPM's
  6. Sep 2, 2009 at 2:02 PM
    kbaum08
    kbaum08 Well-Known Member
    US of A
    09 trd off road dbl cab 4x4 barcelona red
    Jason Topper, Bed Rug, Weather Tech floor liners, Garmin Nuvi 760, Scan Guage, Trd exhaust, AFE dry air filter, shrockworks rock sliders, heated seats Katzkin leather, 2+ inch OME lift shocks etc heavy duty, ARB front bumper, Warn winch, Pia lights, rocktek rear bumper, locking tailgate,
    i use 4th when towing a load and going downhill, to slow things down. I would not worry about shifting into 4th going uphill unless you are experiencing constant shifting from 5th to 4th.
  7. Sep 2, 2009 at 2:05 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    I use 4th gear as well when going up a serious grade. It allows the truck to maintain a steady RPM instead of shifting all of the time when the grade changes. I also use lower gears on the AT when I'm driving downhill on snow. It helps maintain a lower speed without having to brake all of the time.
  8. Sep 2, 2009 at 2:28 PM
    deeznutz
    Seattle, WA
    09 SR5 DC LB 4x4
    Yep. Exact reason why I use 4th going up mtn hills.
