Automatic Door Lock not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cblas87, Apr 11, 2011.
  1. Apr 11, 2011 at 8:54 AM
    cblas87
    cblas87 [OP] New Member
    My Driver side auto door lock is no longer working, only works when I manually lock/unlock on door panel or with the key (not the fob).
    Does anyone have any experience with this problem, I have hear they can be reset, but i don't understand the manual on this, and can't find the correct sequence.
    If not is it possibly a problem with the linkage in the door panel or...?
    2006 Tacoma Prerunner
  2. Apr 11, 2011 at 7:44 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Well normally the Tacomas don't have that feature but since you say "no longer working" I'm assuming you have the factory alarm installed, I'd start with that.
  3. Apr 22, 2011 at 9:25 AM
    cblas87
    No Alarm, just my electronic door lock.
    I do not have an Alarm installed, factory or after market.
    Maybe Automatic was incorrect word.
    What i mean is when I push the door unlock button, either on the door panel or on my key chain remote, it does not lock or unlock my drivers side door, only manually moving the lock from the inside or using my key in the door will lock unlock my driver side door.
    The passenger side door works as it should.
  4. Apr 29, 2011 at 7:00 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I have the same problem on my 2009. The drivers side power lock stopped working. Doesn't even beep anymore on the first fob button press. It does beep twice and unlock the passenger door. Wonder if it is a relay.
  5. Apr 29, 2011 at 7:42 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    The wires lead out of the drivers side kick panel and into the door, find a wiring diagram, which I believe you can find on the12volt.com and check for pulse voltage. Chances are your solenoid is burned up or maybe a loose connection?
  6. Apr 29, 2011 at 7:44 PM
    98tacoma27
    Ben
    Not Beech Creek
  7. May 26, 2011 at 1:26 PM
    mbigpops
    mbigpops Well-Known Member
    2017 TRD Sport
    I have the same exact problem on my 06.
    Anyone solve this yet ?
    If there is no beep on the first button push it sounds electrical.
  8. Jul 9, 2014 at 9:54 AM
    Zakkpw
    Zakkpw Member
    Zak
    ATL
    2011 TRD Sport
    Stereo, various sporting racks, just getting started...
    Similar issue,
    Mine flips about half way then gets stuck when I use the FOB to lock only. Sometimes doesnt even attempt to move at all. I can manualy lock it then unlock with FOB and it works fine. Only gives problems when unlocking... so far anyway. Linkage, motor going weak/ bad?
    2011 Tacoma
  9. Aug 10, 2015 at 5:05 PM
    qncygnnr
    qncygnnr New Member
    Scott
    Western Illinois
    Stock Regular Cab
    2013 Tacoma ... fob does not lock the driver side door. No "beep". Fob will unlock this door. The other three doors lock/unlock with no issues. How do I half-step troubleshoot this? My first thought is that the actuator has some issues.
  10. Aug 10, 2015 at 5:13 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Just a shot in the dark but try a new battery in the remote it cured mine.
  11. Aug 10, 2015 at 5:17 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Great idea.
  12. Jan 26, 2016 at 1:02 PM
    Halo913
    Halo913 Well-Known Member
    Adrian
    Tucson AZ
    Tacoma sport 4x4
    Pro-comp full suspension 3 inch lift, Built right UCA's
    Having the same issues. Started with one door but now all don't lock. The FOB was working and now it doesn't. The battery is good
