Automatic Headlights Not Working Correctly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brandon2330, Apr 16, 2018.
  1. Apr 16, 2018 at 1:18 PM
    Brandon2330
    Brandon2330 [OP] Well-Known Member
    Brandon
    Houston, TX
    2016 Tacoma TRD Off-Road 4x4
    OME Lift & Leer 100XL top
    I've had my 2016 TRD OR DCSB for about 6 months now and recently my auto headlights have not been working correctly. When the switch is on "auto", my headlights never turn off. In order to turn the headlights off in the daytime and get the interior lights to brighten, I have to turn it back to "DRL off". It started doing this about a month ago. Any idea of what could be causing this? Anything helps. Thanks!
  2. Apr 16, 2018 at 1:19 PM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    do you have a sticker or window tint or anything on the lower passenger's side of your windshield? or a hat sitting over there?
    AO-FOSHO, CRSM, USPfan and 2 others like this.
  3. Apr 16, 2018 at 1:21 PM
    Brandon2330
    Brandon
    Houston, TX
    I do. I've got a folded flag over there. I'll check that and see if that fixes it! Thank you!
  4. Apr 16, 2018 at 1:28 PM
    STexaslovestacos
    Sam
    2017 MT TRD OR
    There's a little plastic dome on that side. It's a light sensor, it's how your truck tells whether it's dark out. If you've covered it, the truck thinks it's always night.
  5. Apr 16, 2018 at 1:35 PM
    cemented
    cemented Well-Known Member
    Cole
    Portland, OR
    2017 TRD PRO Cement AT Maggy 84mm OTT
    You can also adjust how long you want your lights to stay on after you turn off your truck and open your door. There is a menu in the stereo to adjust that. Also beep volume on the lock and unlock and if you want to open driver door only with one button push or all doors with one button push.
    Ensemble88 likes this.
  6. Apr 16, 2018 at 1:38 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    That would be your issue!
    SirRoytzz and shakerhood like this.
  7. Apr 16, 2018 at 1:59 PM
    SirRoytzz
    SirRoytzz Taco Enthusiast
    Thats def your issue. Learned that when I left a hat over there lol.
  8. Apr 16, 2018 at 2:39 PM
    Brandon2330
    Brandon
    Houston, TX
    That fixed it! Thanks for the help! Never knew that's where the sensor was.
    TeecoTaco and STexaslovestacos like this.
  9. Apr 16, 2018 at 3:53 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I learned about that sensor when my wife tossed her hat up on the dash, and the headlights came on.
    TeecoTaco likes this.
  10. Apr 16, 2018 at 3:58 PM
    TeecoTaco
    SW Ontario
    If ye had known she was a "puts stuff on the dashboard" kinda chick before ya married her...would ya have?
    Boyitz and Onetime27 like this.
  11. Apr 16, 2018 at 4:21 PM
    dman100
    2016 TRD OR DCSB
    30th anniversary coming up soon. And she had her own pickup truck when we met ... so, yeah. But pretty much the only thing I ever put on the dash is my FastTrak toll transponder. Just before the tollbooth, and then take it off right away.
    TeecoTaco[QUOTED] likes this.
  12. Oct 3, 2018 at 5:41 PM
    CountofQ
    CountofQ Well-Known Member
    Duluth, MN
    2017 'Old Man Tan' AC OR
    I've got to resurrect this thread, as I'm having an issue as well, however it is the total opposite. This evening the headlights would not automatically come on.
    I can get them on by turning the selector to manually turn on, but that is it.
    I played with sensitivity settings, trying to get them to operate, both min and max sensitivity.... nothing.
    I manually covered the light sensor 'button', to block all light.... still nothing.
    Thoughts?
  13. Oct 3, 2018 at 6:29 PM
    Brandon2330
    Brandon
    Houston, TX
    The only thing I can think of is that maybe your sensor has gone bad?
  14. Oct 3, 2018 at 6:57 PM
    CountofQ
    Duluth, MN
    Thanks, guess it's possible. Less than 4k miles on the truck?
  15. Oct 3, 2018 at 10:00 PM
    Brandon2330
    Brandon
    Houston, TX
    That would be crazy if it is a bad sensor for a truck that new. That's just the only thing I can come up with. I'm not too knowledgeable when it comes to electrical stuff :confused: Hope you're able to get it figured out though! I know that it's sure annoying as hell when your headlights aren't working like they're supposed to!
  16. Oct 29, 2018 at 4:04 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I'm having an issue where occasionally my automatic headlights stay on even when it's bright out, I have nothing near the sensor, I have a 2018 Tacoma with approximately 4000 miles on it. Any suggestions?
  17. Oct 29, 2018 at 4:12 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    Tried wiping down the sensor? How long do they stay on?
    You can adjust the sensitivity with the radio.
  18. Oct 29, 2018 at 4:16 PM
    tacomalimited
    Northern NJ
    I tried adjusting the sensitivity, I even tried parking in direct sunlight but they wouldn't go out. I had to turn them off manually, and when I put it back on the automatic headlight setting after manually turning them off, then they stayed off, but they should have went off by themselves in direct sunlight. I don't get it
  19. Feb 9, 2019 at 11:45 AM
    CountofQ
    Duluth, MN
    Mine turned out being related to an aftermarket remote starter.
    I had to send it back for repairs, and left the harness installed while this was being done. During this time, the automatic lights didn't work.
    They began working again after reinstalling the remote start. Just an FYI....
  20. Feb 9, 2019 at 12:09 PM
    VelocitySk
    VelocitySk Well-Known Member
    'Berta, in The Great White North
    2016 Taco Limited
    Been having the same issue as OP. The headlights are in auto position, shut off truck upon arrival at work and lock it using the door handle lock button (which leaves lights on temporarily). Once i get to the shop door, ill lock again (partially ocd driven) and check to make sure all lights have shut off. But they have been staying on lately. BUT it has been -30* to -40* degrees lately, and i expected that it was just a relay freezing/too cold to release. Not sure if factory relay or the aftermarket remote starter box. I figured it was the aftermarket box, not overly concerned as it'll warm up again here and i'm not troubleshooting when its that cold out...
    Db
