Automatic lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Landonri45, Nov 29, 2022.
  1. Nov 29, 2022 at 3:05 PM
    Landonri45
    Landonri45 [OP] Active Member
    2023 Toyota Tacoma SR
    I have a 2023 tacoma sr and was wondering if the lights turn off automatically?
  2. Nov 29, 2022 at 3:13 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Check the stick on the left side of your steering wheel, if you have them, you'll see "Auto". That means the lights come on/off based on how dark it is.
    Most likely you don't have this. Base model SR's don't have shit as far as features.
  3. Nov 29, 2022 at 3:14 PM
    Tacospike
    Two Trucks
  4. Nov 29, 2022 at 3:27 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    The 2009 Prerunner I had didn't have automatic lights. But I set the switch to "On" and left it on all the time. The lights would go off about a minute or so after turning off the ignition.
  5. Nov 30, 2022 at 6:23 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Wouldn't take much effort to find out - leave the light switch on, shut your truck down, check it after about 15 minutes to see if they went out.
  6. Nov 30, 2022 at 6:42 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    My truck doesn't even have an off switch on the stalk. I think Toyota finally is trying to prevent people from driving around at night with no tail lights on.
  7. Jan 3, 2023 at 11:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Get out of here with that practical nonsense. :p
  8. Jan 3, 2023 at 11:33 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    My 23 has a button on the left lower dash
  9. Jan 3, 2023 at 11:33 AM
    CT Yankee
    CT
    Yeah, I know. Common sense isn't too common any more.
  10. Jan 3, 2023 at 11:33 AM
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    that is for the brights to turn off automatic when another car is coming towards you
    Chew likes this.
  11. Jan 3, 2023 at 11:34 AM
    erwigg
    Eric
    Oregon Coast
    it is in the settings on the screen you can have them turn off withthe switch , 30 seconds a mintues or 2 mintues
  12. Jan 3, 2023 at 11:35 AM
    Borracho Loco
    DFW, Texas
    Wrong. The "Auto" on the steering column is so the lights come on when you start the truck. There is a button in the bottom left hand corner, next to the steering wheel. if you press THAT button, then you get the auto-highbeams.
  13. Jan 3, 2023 at 11:55 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    The stalk "Auto" is between DRL mode (whichever you have) and low beam + rear marker lights based on ambient sunlight. The threshold for transition can be adjusted in the infotainment. There is also a user adjustable delay of turning them off after ignition off.
    The switch panel push button "Auto" is high beam dimming based on the headlights of on coming cars. Transition is non-adjustable.
