Automatic shifting?
Discussion in 'Performance and Tuning' started by FLtaco, Oct 12, 2010.
  1. Oct 12, 2010 at 9:11 AM
    FLtaco
    FLtaco [OP] Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    Could you shift a automatic as if it were a manual? Go from L to D as if i had a stick?Aside from having no clutch of course.
    Would this damage anything or not?
  2. Oct 12, 2010 at 9:18 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yes, obviously at the correct speeds... The Taco autos have a selection for each gear (1-5), so you could call it a clutchless tranny. After the fun wears off, the main use of manually shifting your automatic is for slowing down on down grades and not riding on the brake. Don't abuse it however, because brakes are cheaper to replace than transmissions!
  3. Oct 12, 2010 at 9:22 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
  4. Oct 12, 2010 at 9:28 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
  5. Oct 12, 2010 at 12:50 PM
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Thank you all. No need to do it just one of those things I wondered about a automatic. Figured this would be perfect place to ask
  6. Oct 12, 2010 at 3:18 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    I do it sometimes when I want a little bit more power, but after reading part of the thread that MontanaTaco posted, I think I'll take it a little easier. I can't really use my tranny for downshifting at highway speeds though anyways, because I only have 1, 2, and D.
  7. Oct 12, 2010 at 8:03 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
  8. Oct 12, 2010 at 8:05 PM
    jandrews
    '09 FourDubDee TRD OR
    Shifting the auto is useful when towing, going down long grades, and offroad. Otherwise, leave the shifter alone. If you wanted to row your own, they did offer a manual tranny...
  9. Oct 12, 2010 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Shifting the auto can be fun too. Many times, when comming to a turn, or slowing down, I go into first around 25 mph, blip the throttle, and let it slow me.
  10. Oct 12, 2010 at 8:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    after or before I see a speed trap instead of stepping on the brakes engaging the break light I go into 4th on the freeway dropping down a few miles an hour
  11. Oct 12, 2010 at 9:55 PM
    drifter
    Sam
    Oregon
    good stuff
    How many single gears (e.g. L, 2, etc) do you v6 auto guys have?
    v6's must be able to downshift to 1st at higher speed/RPM's?
  12. Oct 12, 2010 at 9:57 PM
    ktmrider
    Junk
    we have all 5
    L, 2, 3, 4, D
  13. Oct 12, 2010 at 10:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The ECU wont let it go into first until about 15 mph. However, Say your going about 25, and you drop it into first gear, you can blip the throttle, and when the revs match the speed, it will go into gear.
  14. Oct 12, 2010 at 10:32 PM
    drifter
    Sam
    Oregon
    good stuff
    Shoot, that's better than my parents's V6 Ford Explorer. That's a nice setup
    All right, cool. thanks guys
