Automatic Transmision start in 2nd gear
Discussion in '4 Cylinder' started by TurboBoss, Jun 4, 2015.
  1. Jun 4, 2015 at 8:04 PM
    TurboBoss
    TurboBoss [OP] Active Member
    Panama Rep. of Panama - Central America
    Hello Guys,
    I have a Toyota Prado 2007 with 4 cylinder 2.7 engine, automatic transmision with only 53,000kms. (TRJ120L - 4 Cylinder 2.7 - 2TR-FE) This engine is exactly the same as the Tacoma.
    I am the first owner and I have never tow a trailer or engage the 4 wd. My wife only use this car as a regular comuter.
    Just recently I found that "sometimes" when I am at a complete stop, when I acelerate to start moving, the car transmision start in 2nd gear intead of 1st gear.
    I note this because the car move slogggish............. Some times I need to press the gas pedal several times to the floor in order that the gear kick down and the trans go into 1st gear.
    This thing only happens sometimes but then the car shifts as regular.
    I check the ATF oil level and is OK. I have not smell it or check the color.
    What can be the problem? Do you think I need to change my Transmision ATF filter and ATF oil to cure this problem?
    Any advise?
    Thanks for your time and help
    Isaac
  2. Jun 29, 2015 at 5:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Failing TCC solenoid in transmission but I could be wrong.
  3. Jun 29, 2015 at 6:04 PM
    TurboBoss
    Hello Steves104x4,
    This last weekend I flush the ATF with Valvoline MAX ATF. So I cant say yet if this has cure the problem. If this thing keep with the same problem, the next thing will be changing the 3 solenoids in the trans. :(
    Rgs,
    Isaac
  4. Jun 29, 2015 at 6:59 PM
    gearcruncher
    Canadain bumper technician
    its a computer controlled transmission . a scanner is your only answer .scan for codes and post back
  5. Jun 29, 2015 at 7:30 PM
    TurboBoss
    Hey Guys,
    I have a WiFi OBD II scanner and I just need to get a APP in order that this thing works with my iPhone.
    1) What AAP you recomend me to get?
    2) Do this WiFi OBD II + AAP will read if I have a transmission code?
    THX
    Isaac
  6. Jun 30, 2015 at 10:00 AM
    Indy
    Indy Master of all I survey.
    I'd recommend torque, but you need a better phone for that app.
    Pabloeeto likes this.
  7. Jun 30, 2015 at 6:01 PM
    TurboBoss
    I have a iPhone 6, do Torque AAP will work OK?
    THX
    Isaac
  8. Jul 1, 2015 at 5:08 AM
    gearcruncher
    AUTO ZONE scans for free .
