Automatic Transmission and Differential Fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackwittmann, May 20, 2019.
  1. May 20, 2019 at 8:47 AM
    jackwittmann
    jackwittmann [OP] Member
    2005 Tacoma, Base model, 4WD
    I own a 2005 Tacoma with 160,000 miles. I bought it from a guy with 149,000 miles on it about a year ago and can tell that automatic transmission fluid and differential haven't been changed in a while because the previous owner did not seem like the type of person to do maintenance. I've been told by my friends who are mechanics to not worry about it and dont bothering changing it at this point and that it will be fine, but I just wanted some other opinions to see if i should at least change the differential fluid.
  2. May 20, 2019 at 8:52 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Rear diff, front diff and xfer case are a no brainer. Change those ASAP. 6 quarts of your favorite diff fluid will do all three.
    Do a drain and fill/fluid check on the transmission and see how the fluid looks. If as dirty as I would expect, it's probably worth dropping the pan and changing the trans filter and doing a full flush.
  3. May 20, 2019 at 8:56 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  4. May 20, 2019 at 10:13 AM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    1st thing I did when I got my 05 Prerunner. Change diff fluid, it was milky.
    Drain and refill tranny.
