Automatic Transmission Downshifting Gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by bajaracer, Nov 17, 2008.
  1. Nov 17, 2008 at 7:54 PM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    I have an 01 3.4 with an automatic and need some advice. Every time that i come to a stop light or close to a complete stop and let go of the gas, it takes awhile for the automatic transmission to downshift to the appropriate gear. Or if i let go of the gas for a couple of seconds and slow down then press on the gas again , it takes a second or two for the tranny to jump into the correct gear. What gives?
  2. Nov 17, 2008 at 7:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    any idea the last time it was serviced......transmission fluid and filter??? if you are unsure, or if it has been a while, the fluid and filter may need to be changed. kinda sounds like the filter may be getting a little clogged.
