Automatic Transmission Fluid for 1st Gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ihavearedtruck, Sep 17, 2018.
  1. Sep 17, 2018 at 5:01 PM
    Ihavearedtruck
    Ihavearedtruck [OP] Member
    NH
    2001 Red Tacoma Xtracab TRD
    I have read a bunch of threads here but am still answerless. I have a 2001 Tacoma AT 3.4L that is low on AFT fluid and I want to fill it up to the correct level. It calls for Dex III but I need help getting pointed in the right direction.
    I can't find straight Dex III anywhere and want to make sure I am putting in the right stuff. I bought this but am now having doubts even though it says it's compatible with transmissions DEX III. I want to confirm that it will mesh well with the ATF fluid that is already in there.
    Is this the original ATF fluid used by Toyota?
    Any help on this would be appreciated. Thanks!
  2. Sep 17, 2018 at 5:05 PM
    Clearwater Bill
    Billy
    Largo Florida
  3. Sep 17, 2018 at 5:33 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Very few ATF's left that actually meet one particular spec, most are multi vehicle formulas to make things easier and conserve shelf space. I recommend Valvoline or ServicePro full synthetic multi vehicle ATF's and they meet Dex 3 as well as Type-IV used in the 04 and newer Tacoma ATX's. You really overpaid for that stuff by the way, ATF shouldn't cost $17 a quart, even the synthetic stuff is a lot less than that. The last flush and fill I did on my Tacoma was with ServicePro and it's got 20k miles on it since then without a single issue to speak of.
    Also, when checking the fluid level, make sure it's HOT otherwise it won't read accurately! A lot of people overfill transmissions because they check them cold and the dipstick reads low, it won't read correctly until the transmission is up to operating temperature and has been there awhile. Make sure to check while in Park also.
  4. Sep 17, 2018 at 5:40 PM
    Ihavearedtruck
    NH
    Awesome! Thank you for the help. I didn't buy the $17 one, I got this stuff for $8 a quart.
    I checked my fluid while the truck was driven for a while and it's really low. I think it is the reason the truck is shifting a little rough. Hopefully solves the slight shimmy I have on the highway too!
  5. Sep 17, 2018 at 5:56 PM
    2004TacomaSR5
    Jon
    Montana
    Is it leaking or burning it?
  6. Sep 17, 2018 at 6:48 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    well, it does say that it is compatible with D-III, in the detailed description....
  7. Sep 17, 2018 at 7:57 PM
    rickyg2008
    rickyg2008 Well-Known Member
    2003 is type Iv
  8. Sep 17, 2018 at 7:58 PM
    rickyg2008
    Owners Manuel I believe states you can use both. Local Toyota dealerships have it
  9. Jan 28, 2019 at 7:16 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    How's your transmission doing? I just bought a 2001 3.4L that shifts a little rough (especially right after going from reverse to drive). Planning on doing a full flush this week.
  10. Nov 12, 2019 at 8:36 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
  11. Nov 12, 2019 at 10:03 AM
    Fatal_Paradox
    Bardstown, KY
    Also same stuff is needed for the power steering ?
    cruiserguy likes this.
  12. Nov 12, 2019 at 10:09 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    Use Dexron VI, fully compatible
  13. Nov 12, 2019 at 10:14 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  14. Nov 12, 2019 at 10:49 AM
    Fatal_Paradox
    Bardstown, KY
  15. Nov 12, 2019 at 10:49 AM
    Fatal_Paradox
    Bardstown, KY
    @Hansel for the power steering or for the transmission?
  16. Nov 12, 2019 at 10:51 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The power steering calls for ATF as well, Dexron III, but you can use what you're gonna use now with your tranny
    Fatal_Paradox[QUOTED] likes this.
  17. Nov 12, 2019 at 10:52 AM
    cruiserguy
    Elijah
    SEKS
    You're just doing a drain and fill on the transmission right?
  18. Nov 12, 2019 at 10:57 AM
    Fatal_Paradox
    Bardstown, KY
    @cruiserguy yes. I may drop the pan and inspect the filter. Not flushing it though.
  19. Nov 12, 2019 at 10:58 AM
    Black DOG Lila
    Virginia
  20. Nov 12, 2019 at 10:59 AM
    cruiserguy
    Elijah
    SEKS
    Cool, you'll be good. And you doing the turkey baster method for the swapping the fluid in power steering reservoir?
