Automatic Transmission Fluid for 1st Gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ihavearedtruck, Sep 17, 2018.
  1. Nov 12, 2019 at 11:01 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    @cruiserguy Yes. I may take off the return line and move my wheels back and forth manually with the truck off. Coming up on 200k so doing all fluids. Ordered some amsoil for the diff's and transfer case.
    cruiserguy likes this.
  2. Nov 12, 2019 at 11:03 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Sounds like you got a good game plan in place:cool:
  3. Nov 12, 2019 at 11:04 AM
    Fatal_Paradox
    Bardstown, KY
    @cruiserguy Trying to. I just need a transmission drain plug washer now.
  4. Nov 12, 2019 at 11:25 AM
    cruiserguy
    Elijah
    SEKS
    Can you order it online or do you have to pick it up in store today?
    Like are you wanting to do the work today? So ordering the washer online no good? What local parts stores are around you? Orielly or Vatozone?
  5. Nov 12, 2019 at 11:27 AM
    Fatal_Paradox
    Bardstown, KY
    @cruiserguy I would prefer to order it online. Not in a hurry still waiting on other parts to come in. I cant seem to find a part number for it.
  6. Nov 12, 2019 at 11:31 AM
    cruiserguy
    Elijah
    SEKS
  7. Nov 12, 2019 at 11:51 AM
    Fatal_Paradox
    Bardstown, KY
    Yeah I looked at that. If you read it doesnt actually come with one for the transmission.
  8. Nov 12, 2019 at 12:21 PM
    cruiserguy
    Elijah
    SEKS
    Oh I foolishly assumed it was gonna be the same size as one that it's included. I'll see if I can find a part number and some info or specs on it
    Fatal_Paradox[QUOTED] likes this.
  9. Nov 12, 2019 at 12:28 PM
    cruiserguy
    Elijah
    SEKS
    I believe the washer for the transmission drain plug is interchangeable with the washer for the transfer case drain plug
  10. Nov 12, 2019 at 12:29 PM
    Fatal_Paradox
    Bardstown, KY
  11. Nov 12, 2019 at 1:32 PM
    cruiserguy
    Elijah
    SEKS
    I think I'm wrong on that!
    I'll double check later when I can get to a desktop
  12. Nov 12, 2019 at 1:43 PM
    cruiserguy
    Elijah
    SEKS
    Just from eyeballing it, I can tell the washer for the transmission is more like the size of the washer for the oil pan drain plug. Like real close but looking up part numbers we'll see better.
  13. Nov 12, 2019 at 2:06 PM
    cruiserguy
    Elijah
    SEKS
    Automatic transmission drain plug gasket original part number was 35178-50010. This number was discontinued and superceded with part number 35178-30010.
    This washer was used on the auto transmissions of lots and lots of Toyotas. Maybe throwing that part number into Amazon search would get a different result?
    Edit: looking on Amazon it does look like the washer you need for the transmission is a common one to be included in the sets they sell like in earlier links in your thread.
    Fatal_Paradox likes this.
