Automatic transmission fluid leak / replacement question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ke2013taco, Jan 16, 2022.
  1. Jan 18, 2022 at 9:02 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Not to mention the guys like me who tow fairly frequently. I’d like to be able to pull the stick and inspect the fluid. Pulling a stick beats crawling under the truck and removing bolts.
    Raylo[QUOTED] likes this.
  2. Jan 18, 2022 at 9:10 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Plus, for you guys who tow, having a dipstick not only would let you check the level easily but also the condition of the fluid by color and smell. Towing hard can cook tranny fluid. Easy to neglect those checks when you have to crawl under.
    TnShooter[QUOTED] likes this.
  3. Jan 18, 2022 at 9:13 AM
    TnShooter
    Deogee
    STOCK
    Indeed it is, AFAIK my fluid is fine.
    I haven’t crawled under and checked;)
  4. Jan 18, 2022 at 9:27 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    OP, waiting to drop the pan until after you’ve found and repaired the leak and replaced the fluid and idled while cycling all the gears is a good idea in my opinion. I know that’s a pain because you’ll have to replace 3-4 new quarts, but it permits you to see the full impact of cycling fluid, as far as what’s on the filter and the magnets. Then you can replace the filter if desired, and clean any contaminants off the pan and magnets.
    This also allows you to better check for any major transmission damage (metal fragments on the magnets) which I sincerely hope not to be the case.
    gearcruncher likes this.
  5. Jan 18, 2022 at 9:43 AM
    Raylo
    MD, USA
    LOL... yes, ignorance is bliss. Says so right there in the owner's manual. ;-) And repeated here by many others who have not yet had their leak!
  6. Jan 18, 2022 at 10:15 AM
    TnShooter
    Deogee
    STOCK
    Between the rear axle seal leaking sporadically , and front diff breather puking fluid out the breather. I’m half way scared to crawl under there look any more :anonymous:
  7. Jan 18, 2022 at 12:08 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Agreed, but the OP had a catastrophic leak.
  8. Jan 18, 2022 at 12:47 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I’d just repair the break in the line and fill the tranny back using the fluid check procedure. Then wait until it’s warmer to drop the pan and replace the filter. I’m not sure if the pan uses an actual gasket or gasket maker goo, but if the latter I would definitely check its curing temperature if you go this route since it’s super cold where you live.
  9. Jan 18, 2022 at 12:50 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    My 2015 has an actual gasket….OP can verify on his vehicle with a quick eyeball check.
  10. Jan 19, 2022 at 1:46 PM
    ke2013taco
    ke2013taco [OP] Member
    Western New York
    2013 Silver Access Cab SR5 4x4
    Gotta love old 4 wheelers..... My old honda fourtrax was able to tow my tacoma. I couldn't believe it! The fourtrax frame was hanging up in the snow a bit, but it still moved my tacoma....
    Now I'm in a garage... I towed it maybe 3/8 of a mile, very low speed.. Just waiting on a kerosene heater to be dropped offf...... Did someone's brake pads and rotors in exchange for use of garage.....
    Now I can finally get some work started on my truck!!
    Must of looked funny to the people passing me - a little old four wheeler towing a truck.......
  11. Jan 19, 2022 at 5:31 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    ATVs are great for that kinda stuff, we have a Yamaha Big Bear 4x4 at the shop I work at that we use to push disabled vehicles into the shop with.
