Automatic Transmission Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XC4ME, Feb 17, 2012.
  1. Feb 17, 2012 at 8:27 PM
    XC4ME
    XC4ME [OP] Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    While accelerating slowly in traffic, my truck will shudder (like driving over railroad tracks) when it shifts from 3rd to 4th and 4th to 5th between 30 to 40 mph. If I accelerate normally or swiftly it seems to shift fine.
    It’s a 2005 DCSB Prerunner still on the original fluid and has 103,000 miles on it. Could it be I just need a fluid flush?
    Thanks
  2. Feb 17, 2012 at 8:30 PM
    Syncros
    Syncros Well-Known Member
    Had mine flushed at around the same mileage, made a lot of difference.
  3. Feb 17, 2012 at 8:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm putting my $ on the driveshaft carrier bearing. Get underneath and grab the driveshaft and push and pull it side to side; there should be very little to no play. images_3ef3b20f8169c812b8001182284e5eca6adb60c2.jpg
  4. Feb 17, 2012 at 8:41 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I'd start with tranny flush
  5. Feb 17, 2012 at 8:41 PM
    XC4ME
    Thanks Steve I will check that out. Thanks for the pic too! :)
  6. Feb 17, 2012 at 8:45 PM
    XC4ME
    Yes, I think no matter what, I will get the flush. :thumbsup:
  7. Feb 17, 2012 at 8:46 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    When mine "went" on my old truck, the driveshaft would sway like 5 inches either way; I can't beleive the thing didn't fly off. Good luck. Cheers. Steve
  8. Feb 18, 2012 at 11:53 AM
    XC4ME
    Ok, I checked the carrier bearing and I can move the driveshaft up and down at least an inch and side to side a little less. I take it this is too much play?
  9. Feb 18, 2012 at 1:50 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Shudder during a shift usually means the friction modifier in the tranny fluid isn't working anymore. Time for a fluid change.
  10. Feb 18, 2012 at 2:42 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    OP, sounds more like a driveshaft problem than a transmission problem.
  11. Feb 20, 2012 at 8:20 PM
    XC4ME
    Well took it down to the dealer today. Thier senior Tech said the carrier bearing was fine and the tranny fluid didn't look bad for the miles. He thinks it's torque converter shudder. He cleared the computer and told me to see how it runs and let him know tomorrow. If I still have the issue, new converter I guess.
  12. Feb 20, 2012 at 8:35 PM
    Syncros
    I recommend the fluid change. Its $189, my shift quality is much better.
    My mileage was similar when I had it done, I had a shudder on up shifts, especially 1-2, and 4-5. Its much better now, well worth it!
  13. Feb 21, 2012 at 7:03 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    It is torque converter shudder. Mine does it too, especially going up a hill. I changed my fluid myself which only gets 3 quarts of the 11 total quarts and it went away completely for a week. Now it is back but not as bad. My next move is to bite the bullet and get it flushed for a complete fluid change.
  14. Feb 21, 2012 at 7:55 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I think at 100k miles they recommend a flush and fluid change, go do it, bet it will help!
  15. Feb 24, 2012 at 8:57 PM
    XC4ME
    Had the dealer do a flush today, $199 plus tax. Didn't notice the problem on the way home but, I only live 15 minutes away. We'll see what happens after I drive it around a bit tomorrow. Be nice if thats all it was.
  16. Feb 24, 2012 at 9:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What dealer did you go to? The ones near me keep quoting 350 to 450 bucks for a flush!
  17. Feb 24, 2012 at 9:28 PM
    XC4ME
    Hi Chris, Avondale Toyota. Thier regular price is $239 but, the service guy I see there (CeJay) gave me a break. They seem to be pretty straight up for a dealership.
  18. Feb 24, 2012 at 9:34 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Same thing I had at 100,000 miles got it flushed and perfect now no issues put the top stuff in this time
  19. Feb 25, 2012 at 6:58 AM
    T-Rex266
    Elon
    My friend, who is a service tech "mechanic" at Toyota recommends flush at 60k
  20. Feb 25, 2012 at 7:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know! And that was for a Flush, right?
