Automatic Transmission locked in park
Discussion in 'Technical Chat' started by river rat 69, Jan 3, 2014.
  1. Jan 3, 2014 at 4:33 PM
    river rat 69
    river rat 69 [OP] Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    My 07 4.0 auto transmission has been doing fine , but this morning It would not come out of park..Did the screw driver thing and got it in drive Now the check eng. light is on & the turn signals & heater fan are not working...Any one come across anything like this...Thanks Jim
  2. Jan 3, 2014 at 5:10 PM
    Tacoma Mike
    Southern Maine
    Check your fuses Jim.
    You hurt her somehow..
    You have a multi circuit failure.
  3. Jan 3, 2014 at 5:12 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Man she was doing fine Thurs night no mods not even under the hood and this morning boom all kinds of stuff gone...:(
  4. Jan 3, 2014 at 5:19 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Electrical seems to be a common connection there. I'll check the wiring diagrams. Odd symptoms though - maybe a wire came off the brake switch at the brake pedal?
    - ie need to apply the brake before switching out of park.
  5. Jan 3, 2014 at 5:20 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Check your IGN 1 and IGN 2 fuses. Had the same thing happen to mine, dont remember which fuse it was that was blown.
  6. Jan 3, 2014 at 5:24 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    I have running lights and brake light lights ..Also foot pumping the brakes did not help it.
  7. Jan 3, 2014 at 5:52 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    One of the IGN fuses.
  8. Jan 3, 2014 at 5:53 PM
    Tacoma Mike
    Southern Maine
    IG2 but he didn't mention if his power windows work or if his tpms light is on.
  9. Jan 3, 2014 at 5:58 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    TPMS light is on,, door lock & windows work..
  10. Jan 3, 2014 at 6:03 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How old is the battery that's in the truck?
  11. Jan 3, 2014 at 6:05 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Simi new about a year old..
  12. Jan 3, 2014 at 6:06 PM
    Tacoma Mike
    Southern Maine
    The scenario is not exactly like what I had with a cust.
    Long story, not important .
    Like Rich and Chris said start with the Ig fuses.
    IG2 runs a lot of sub systems.
  13. Jan 3, 2014 at 6:10 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    its a fuse...same exact thing happened to me....cant remember what fuse though
  14. Jan 3, 2014 at 6:13 PM
    anthony250f
    Anthony
    San Diego, CA
  15. Jan 3, 2014 at 6:55 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
  16. Jan 3, 2014 at 7:04 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    ^^^ check the wire to the brake switch though first, as that maybe the source of the problem? The fuse blew for a reason.
  17. Jan 3, 2014 at 7:13 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Nothing lose & I have brake lights:confused:
  18. Jan 3, 2014 at 7:15 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    :bananadance::taco:
  19. Jan 3, 2014 at 7:43 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Im going over it in the Am....Also let my tech pal go over it when he can make time,,:)
  20. Jan 4, 2014 at 4:42 AM
    Tacoma Mike
    Southern Maine
    Awesome.
    :yay:
