Automatic transmission shift points
Discussion in '1st Gen. Tacomas (1995-2004)' started by stickhead, Jun 3, 2011.
  1. Jun 3, 2011 at 5:35 PM
    stickhead
    stickhead [OP] New Member
    02 Toyota Tacoma
    Is there a way to modify my automatic transmission or differential to change the shift points? I am always having to put the pedal to the metal to try and get it to downshift.
  2. Jun 3, 2011 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! grab the lever and move it to the gear you want it to be in.
  3. Jun 3, 2011 at 9:55 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    I've found in many cars that have a overdrive button, if you turn overdrive off, it will also change all of the shift points as well and move them to a higher rpm. Makes cars drive much much better around town with steep hills between 25-50mph.
  4. Jun 4, 2011 at 2:34 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    x2
    Try driving with ECT on for a while. If you want to change it even more drive with ECT on and o/d off
