Automatic Transmission shifting issues
Discussion in 'Technical Chat' started by bartman, Jul 19, 2012.
  1. Jul 19, 2012 at 9:11 AM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    I've had my 2011 Tacoma 4x4 for a little over a year now and ever since I got it I've noticed that the transmission can't decide what gear it wants to be in. It drives me crazy because it dithers back and forth, first a lower gear, then shifts up, then back down and so I when I'm running through town specifically around 30 mph. I've even noticed it happening at even higher speeds now. Is this something that can be adjusted? A guy at work suggested re-chipping the computer that controls the tranny using a Jet performance chip but I didn't see one available for my truck. I'm open for information or suggestions. Thanks!!
  2. Jul 19, 2012 at 9:29 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Did you have the transmission TSB done? That helps out a bit.
  3. Jul 19, 2012 at 9:54 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Don't waste your money on a JET chip!!! My truck is not comfortable driving at 30mph. The trans shifts up and down, like the gearing is off at that mph. I was very lazy one day driving home and put the cruise control on at 30mph, truck could not decide which gear to stay in. I am heavily modded so maybe that's it.........
  4. Jul 20, 2012 at 3:22 AM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    Ok, I'm a bit naive to the acronyms, unfortunately. What's a TSB? Thanks!
  5. Jul 20, 2012 at 9:33 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Its not normal. Take it back to the dealer, it should be under warranty.
  6. Jul 20, 2012 at 11:09 AM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    I'm actually going in for the 20k service tomorrow so I'll hit them up on the shifting issue. Bet they say it's "normal".
  7. Jul 20, 2012 at 11:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    TSB stands for Technical Service Bulletin. It is predominantly meant for dealer-level technicians to help them with common procedures, specs, or problems, allowing them to do their job better. They are also used by "do-it-yourselfers" who want to keep appraised of problems involving their trucks, and possibly fixing it themselves in order to save the high cost of dealer repairs.
  8. Jul 21, 2012 at 1:26 PM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    I guess I'll find out Thursday when I take it back in for a technician to check it out. I let you know how that turns out. Thanks for the information so far!
  9. Jul 22, 2012 at 5:43 AM
    12Tacoma
    12Tacoma Well-Known Member
    TN
    2012 trd off road 4x4
    husky liners, undercover tonneau, ome 885's, 2" aal, 265/75/16 duratracs.
    Please update if you find out something.
    My 2012 surges and shudders between 40-42 mph under light throttle. I told dealership about it at my first oil change and it was the usual line "nothing found"
    My fix is to not drive at that speed and accelerate harder through 40mph which works well but on 30k truck it is annoying. It has to be in the programming my 06 tundra same tranny i think never did it smooth as silk at all speeds and shift points.
  10. Jul 23, 2012 at 5:49 AM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    I will definitely let you know. I go in Thursday afternoon for the technician to check it out. Hopefully I can duplicate the problem for him. Talk to you then.
  11. Jul 23, 2012 at 8:25 PM
    morrisminor
    morrisminor Member
    Mountain View, CA
    2012 Tacoma Pre-Runner
    Camer shell, front bumper guard
    My 2012 Tacoma automatic gets to bucking if I'm stuck in heavy traffic at 30-40 MPH. The only way to control it is by shifting it down to 3rd gear. When the traffic lets up I have to remember to shift back to "D".
    Of course, the dealer tech says "no problem found". The foreman is pretty cool. He pretty much said that's the way it is.
  12. Jul 23, 2012 at 8:29 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Didn't know about the .... transmission TSB ??? ... :confused:
  13. Jul 27, 2012 at 2:51 PM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    Ok, here's the bottom line........Service man said it's performing by the book. It's shifting into overdrive and back out to satisfy emissions, if I want it to stop he says to put it in 4th gear until I get out of the low speed (30 mph) area. Jeez, why didn't I think of that!
  14. Jul 27, 2012 at 2:52 PM
    bartman
    bartman [OP] Member
    Bill
    Michigan
    Tacoma 4x4
    Cap Wheels
    Oh yeah, forgot to tell you that they checked for a TSB and there was none. Guess I live with it.
  15. Jul 28, 2012 at 12:24 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Makes sense (geez why didn't I think of that)! Do any of you still get that 1st gear drag the sudden shift into second?
  16. Jul 28, 2012 at 12:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There is a tranny TSB for an odd 1st to 2nd shift pattern for the 08-09's , not sure if it applies to your 07
  17. Apr 12, 2013 at 8:51 AM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    Did you get this fixed??
    Mine is doing the identical thing...started within the past 2 weeks.
  18. Apr 12, 2013 at 8:54 AM
    OZ-T
    Peter North
    British Columbia
  19. Apr 13, 2013 at 9:13 AM
    morrisminor
    morrisminor Member
    Mountain View, CA
    Mine does the same surging and bucking at light throttle 35-40 mph.
    I believe it's in the trans shifting or the throttle cut-off. It seems to be normal for a couple of year models.
    The only way to tolerate it is to put the auto trans in #4 or #3.
    Mine also pings badly driving around town, especially in low speed turns, on light throttle. This also appears to be normal. The engine is just running too slow in an attempt to get good milage.
    My '98 T100 had none of these problems. Disappointing.
    Mike, 2012 Tacoma
  20. Apr 14, 2013 at 4:58 PM
    93civEJ1
    09 DC TRD OR
    no...im pretty sure the shudder feeling is not anywhere near normal. I drove for thousands and thousands of miles without this issue.
