Automatic Transmission slow to go in cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by DecaturTide, Jan 9, 2015.
  1. Jan 9, 2015 at 6:37 AM
    DecaturTide
    DecaturTide [OP] Well-Known Member
    River City
    2016 SR AC BARCELONA RED
    Just changed a leaking radiator, and then topped off the transmission fluid.
    Weather has been between 6 degrees and 11 degrees the last couple of mornings. When I crank her up and pull out of the garage in reverse it's fine until I'm in the road and put her in drive and it just sits there or is very slow until it warms up a bit.
    Any ideas on what could be going on?
    It's a 2000 3.4 prerunner.
  2. Jan 9, 2015 at 6:45 AM
    EngRWW33
    EngRWW33 Well-Known Member
    I am dealing with the same thing right now. Check fluid level and make sure it not low.
    I'm planning to drop the pan and change the filter this weekend. I'm thinking that the filter may be getting clogged while the fluid is still cold (thicker).
  3. Jan 9, 2015 at 7:59 AM
    DecaturTide
    River City
    Thanks EngRWW33.
    Anyone else?
  4. Jan 9, 2015 at 9:13 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    mine has never liked going out of 2nd when its cold until it warms up for a mile or so. Leaking radiator? Wasn't leaking into the transmission cooler was it?
  5. Jan 9, 2015 at 10:32 AM
    DecaturTide
    River City
    Nope, leaking out of the top plastic piece.
  6. Jan 9, 2015 at 10:40 AM
    gearcruncher
    Canadain bumper technician
  7. Jan 9, 2015 at 7:16 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I have exact same problem. When cold it will not want to shift out of second.
  8. Jan 9, 2015 at 10:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Fluid has got to get nice & warm to expand , then things start running like they should, you guys in cold/sub zero environments are going to experience this time to time I'd think...
  9. Jan 11, 2015 at 10:48 AM
    DecaturTide
    River City
    Had it flushed Saturday. Good as new!
  10. Jan 11, 2015 at 6:45 PM
    DestroyerLite
    DestroyerLite Well-Known Member
    DFW
    04 Tacoma SR5 V6 4X4 Auto
    Mine has been doing this since new. Even after s fluid change it's the same. It just likes to run all nice and warm. Just be easy on it, mine will eventually shift into third at about 2750 rpm or so.
    --Dan
  11. Jan 12, 2015 at 10:36 PM
    MikeZ
    MikeZ Well-Known Member
    Toyota tends to do this in order to get the drive train warmed up. My dad's 2010 corolla does the same and he contacted the dealership and the technician said that toyota holds back the shifts points to get it warmed up sooner.
  12. Jan 13, 2015 at 6:01 AM
    EngRWW33
    The issue here is when initially put into drive on a cold start (for me, around 0-10 deg F) the transmission slips and the truck will barely move if at all until warmed up a bit. Reverse is fine, Low is fine... at least for me.
    Most transmission will hold onto gears longer until the engine warms up.
  13. Jan 13, 2015 at 6:54 AM
    DestroyerLite
    DFW
    Have you checked the level of the fluid after you topped it off and drove around for a bit? Also is the fluid still nice and pink and not have a burnt smell?
    --Dan
  14. Jan 13, 2015 at 9:37 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    by the way, if you've ever noticed the little sticker on the AT dipstick it says that you do not need to change the fluid under normal driving conditions. had a Toyota tech tell me this as well. don't have a manual handy to see if there is a scheduled maintenance for this.
  15. Jan 18, 2015 at 12:05 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    1st gens are supposed to be "drain & fill" every 35k IIRC for the A340F automatic..
  16. Jan 18, 2015 at 8:54 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    hmm, just went to:
    http://smg.toyotapartsandservice.com/guides.php
    and it looks like it's every 30k... but mainly for "special operating conditions" which is towing or dusty/back roads. most of them say to inspect the ATF but not to change it unless it meets that special condition.
