Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GARTHRYAN, Oct 9, 2014.
  1. Oct 9, 2014 at 5:47 AM
    GARTHRYAN
    GARTHRYAN [OP] Member
    Garth
    Vancouver
    Tacoma TRD Sport
    I recently purchased a 2014 TRD Sport with the auto transmission and this is my first automatic. I was chatting with a guy I know and he mentioned that when you stop at a red light shift your transmission into neutral, this keeps all the fluids flowing in the transmission but it releases the stran on the drive train. Ultimately prolonging the life on your transmission.
    Any thoughts on that?
  2. Oct 9, 2014 at 5:52 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I had coworker do that in a old Honda accord, why I don't know. 165K on my Tacoma and I've never done that....shifts just fine. Changing the fluid will prolong the life.
  3. Oct 9, 2014 at 7:09 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    My 04 had 230k miles on the original tranny fluid, I towed all the time, no issues. I'd say that is not a necessary thing to do, but probably can't hurt as well.
  4. Oct 9, 2014 at 8:06 AM
    oldstick
    oldstick Medicare Member
    GA
    They taught us back in the 70s drivers ed to always hit neutral then set the brake before shifting into park especially parking on inclines. Supposedly to save strain on the tranny, but I never found out if that was a true issue or not.
  5. Oct 9, 2014 at 8:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LOLOL WTF.... no this will increase clutch pack unloading and loading reducing the life of the trans.
    if you are moving leave it in drive.
    That stated, when i park i always go neutral, parking break, shift to park. Old habbit from my chevy that if you didnt do this you could bind the trans so hard that it wouldnt come out of park if it was on a hill or something.
  6. Oct 9, 2014 at 8:27 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Don't be scared to shift through the gears while you're driving but just leave in whatever drive gear ( L-D ) you are in at a stop and as mentioned , I also do the N ~ parking brake ~ P routine when you are parking it
  7. Oct 9, 2014 at 8:53 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    This.
  8. Oct 9, 2014 at 8:55 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Just leave it in drive.:rolleyes:
  9. Oct 9, 2014 at 9:37 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Not necessary and may do more harm than good. The small amount of heat generated in the fluid from idling at a red light is easily dissipated by the cooling system.
    If I'm at a long red light, for convenience, I sometimes shift into neutral and put on the parking brake just so I don't have to keep the brake pedal pressed all the time.
    Yes I still see this advice in the Aamco literature. This so the parking brake holds the vehicle weight instead of the parking pawl in the tranny.
  10. Oct 9, 2014 at 11:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I had a guy tell me that the Tacoma had a "New High Tech Electronic Active" suspension on it, then he began jumping up and down in the bed, rocking back and forth yelling "SEE!!??"
    Some people like to open their ass, and talk out of it.
