automatic type rear lockers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cclax2145, Dec 15, 2008.
  1. Dec 15, 2008 at 6:08 PM
    cclax2145
    cclax2145 [OP] Well-Known Member
    Houston
    2002 prerunner SR5 Blacked out
    Deckplate mod, K&N drop in, blacked out tails and emblems, 3 inch toytec spacer/AAL lift, Alpine head unit, Boston acustics speakers, and 10 inch image dynamics sub (in custom seat/box), Alpine EQ, Flowmaster 40 series, and viper alarm system, 33inch bfg MTs, 15inch black steelys
    Does anyone know how good the automatic rear lockers are. Do they cause a lot of tire wear or anything along those lines. And if they are good what type should i get? Thanks
  2. Dec 15, 2008 at 6:12 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I'm not quite sure what your talking about? Are you referring to the e locker?
  3. Dec 15, 2008 at 7:15 PM
    cclax2145
    Houston
    No the type of lockers that are always locked but will let one tire spin a little faster than the other such as a Detroit locker.
  4. Dec 15, 2008 at 7:30 PM
    sonjay
    sonjay Well-Known Member
    I've heard good things about aussie lockers, never run them tho.
  5. Dec 15, 2008 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Power Trax makes a couple of good ones, the Lock Right, and the No Slip. The only odd behaviors they have is if you give it gas while turning, they will lock, thus causeing the inside tire to scrub. They also can make a "Pop" sound from time to time, but its normal.
  6. Dec 15, 2008 at 7:50 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    My Toyota LSD rear end does this. It kinda ticks me off because I know that it is eating tires much faster than if it was an open diff or a manual locker. However the clutch disc LSDs (like the Toyota LSD on the 05-08s) don't make a popping sound. They just wear out clutches. :rolleyes:
