Automatic V6 Acceleration is more sluggish and struggling to go above 2000 RPM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr. Steelio, Jan 26, 2023.
  1. Jan 26, 2023 at 2:11 PM
    Mr. Steelio
    Mr. Steelio [OP] Member
    Alex
    2011 Silver Tacoma TRD Sport
    K&N Series 63 AirCharger Cold Air Intake, Flowmaster Outlaw Extreme Cat-Back Eshaust System
    Had a issue two days ago where my 2011 Tacoma TRD Sport with a 4.0L V6 auto started acting sluggish while accelerating and struggles to go past 2000 RPM. I was doing research and heard things like how the fuel filter needs to be changed, the transmission fluid also needs to be changed, and the worst case scenario being the catalytic converters have gone bad. I have also installed a K&N cold air intake. Has anybody ran across an issue like this? Thank you in advance and I am open to answer more questions.
  2. Jan 26, 2023 at 2:39 PM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    no fuel filter on the 4.0, dump a bottle of seafoam in the tank & clean the MAF. when was the last time the plugs were changed?
  3. Jan 26, 2023 at 2:42 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    There is a fuel filter. Its in the pump assembly. Its non replaceable, so often people upgrade to a different pump as well as an external fuel filter.
  4. Jan 26, 2023 at 2:44 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Did this start after you installed the cold air intake?...
  5. Jan 26, 2023 at 2:45 PM
    Mr. Steelio
    Alex
    I installed the intake a few months back way before the issues started
  6. Jan 26, 2023 at 2:46 PM
    Mr. Steelio
    Alex
    I changed all the spark plugs back in the late summer of last year. So far I have put 10-20 thousand miles. So it was fairly recently.
  7. Jan 26, 2023 at 3:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you have a check engine light on?
    Do you have access to a scan tool?
    Even if you don’t have a CEL on, scan tool data can sometimes tell you a lot.
  8. Jan 26, 2023 at 3:19 PM
    Mr. Steelio
    Alex
    My check engine light did not go off and I could go to a local autozone and use their scan tool. However, would anything pop up even without the check engine light turning on?
  9. Jan 26, 2023 at 3:23 PM
    TnShooter
    Deogee
    STOCK
    Yes, pending codes.
    But that isn’t really what we are looking for.
    If your CEL in on now. We need those codes.
    You may be in Fail safe mode, which limits you to about 2,500 rpm.
    And cuts timing way back. = SLUGGISH
  10. Jan 26, 2023 at 3:30 PM
    Mr. Steelio
    Alex
    Ill be sure to check and get back to you. Thank you
    TnShooter[QUOTED] likes this.
  11. Jan 26, 2023 at 4:55 PM
    Mr. Steelio
    Alex
    Just used the scanner and no pending codes showed up. I remember the transmission fluid has not been changed in a while. You think that might be the issue?
  12. Jan 26, 2023 at 5:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Nope.
  13. Jan 26, 2023 at 5:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Make sure your brake light switch is working properly, if the PCM sees a brake input it will reduce engine power.
    GilbertOz and TnShooter like this.
  14. Jan 27, 2023 at 1:04 AM
    Stemmy
    Rob
    Pennsylvania
    yes the sock filter, but I was referring to an external, maintenance item.
