AutoTransmission Screen Filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Jun 2, 2010.
  1. Jun 2, 2010 at 11:58 AM
    twfsa
    twfsa [OP] Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Bought a used 04 Tacoma V6 50K miles don't know what kind of life it has had, transmission shifts great, but I was thinking of doing a drain and refil, For those of you that have removed the pan and washed out the filter was it that dirty, and how many miles were on the vehicle.
  2. Jun 2, 2010 at 12:22 PM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    My cousin has an 02 4cyl. He does a lot of towing with it. He had no idea the tranny fluid needed to be done until I brought it up. His truck had 160k when we dropped the pan. F%@$ the fluid was practically brown. As a matter of fact I remember thinking that maybe he was better off not doing the flush. Anyways, the filter was pretty much the same as the one my cousing bought from Toyota. Really it was just the fluid that was dirty. Hope this helps, I know you have the V6 4x4 and his was a 4cyl 2wd.
  3. Jun 2, 2010 at 12:37 PM
    Barnone
    Barnone Guest
    Does your AT have a drain plug? If you remove the pan you will only get about 2 and 1/2 quarts of fluid out. Might as well just remove the drain plug if you have one.
    On my 2002 2.4l auto, I drained the fluid at 90k milles and got out about 2 and 1/2 quarts out. If I remember right the owner' manual said that is how much you would get out on a drain. Total capacity is about 11 quarts but again check your owner's manual. The fluid drained out was brown instead of red like new fluid. So I drove the truck for a while and then repeated the drain and drive for three more times. I am now at 93k miles and the fluid is red like it should be.
    The other option is a flush which is detailed some where on this site but after reading the procedure, I decided that was better done by a trusted shop if you can fine one.
    Again, my owners manual just says to do the drain and refill.
  4. Jun 2, 2010 at 3:22 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Seems to me I read that on mine you get 4 qts on a drain and refil could be wrong tho.
  5. Jun 2, 2010 at 3:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on a drain and refill.....they all will be give or take a bit....but it right at 3 quarts on a drain and fill for my truck. now...that said....when i drop the pan and clean the filter screen.....its more right over 4 quarts. 5 usually does it.
  6. Jun 2, 2010 at 4:42 PM
    montanabay
    montanabay Active Member
    CA
    2.7L 4WD AUTO
    if it is hot and level you'll get what they say (engine size, and drive model make the difference), if the front is up on blocks so you got a nice grade, you get more out of the torque converter, which holds the bulk of it. Last time I did this I had the front way up (be sure to chalk it up good!) I got close to 5-6qts out of my A430F transmission.
  7. Jun 2, 2010 at 7:41 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Seems odd that removing the pan gets more put than just pulling the plug. Maybe removing the screen alows more to drain out.
  8. Jun 2, 2010 at 8:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....there is always a lil more left in the pan even with just draining it...but when the filter screen is unbolted...you get more out then too.
  9. Sep 5, 2015 at 9:03 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Just stumbled on this page. If your looking for a DIY on flushing the transmission there's a how to on my build. I did it not to long ago. Feel free to pm me with any question.
