Autoventshade In-Channel Ventivisor "AVS" Decal Removal?
Discussion in 'Detailing' started by Slim_Shady, Feb 7, 2022.
  1. Feb 7, 2022 at 10:34 AM
    Slim_Shady
    Slim_Shady [OP] Member
    Scott
    2022 Tacoma SR5 - Double Cab - Extended Bed
    Got a set of Autoventshade's low profile in-channel ventivisors for my 22 SR5, and they look great except for one flaw: there is a white "AVS" logo on the front two visors. It isn't a sticker or anything that can obviously be removed. The only method I can imagine to remove it is by sanding it, which is obviously a bad idea.
    The advertisements don't show the visors with this logo, and it sticks out like a sore thumb against the sea of black. Has anyone successfully removed these without damaging the visors themselves? Thanks.
  2. Feb 8, 2022 at 5:51 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    That is screen printed on the plastic. I got mine off by using a solvent and paper towels. It's been a long time since I did mine, but I think I used Naptha. If you use acetone or lacquer thinner be careful, they could change the surface of the plastic if left on too long and it may look like a dull spot.
  3. Feb 11, 2022 at 6:24 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Good olde Sun took care of mine. UV rays Ya know.
    My 2013 is white so the white letters on the shade matched.
    TOMB
  4. Feb 15, 2022 at 7:20 AM
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    I remember reading on here that using Food grade silicone would do it. So probably using regular silicone would do it too. I would do that prior to installation to avoid getting it on the paint and try a little section first. You could also cross check what they are made out of to make sure silicone won't harm the plastic..... which I don't think it would but do your research. I have not tried this so that's my disclaimer as per my attorney's instructions....:rolleyes:
