Autozone battery testing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jacobb81, Sep 30, 2024.
  1. Sep 30, 2024 at 5:50 AM
    jacobb81
    jacobb81 [OP] Well-Known Member
    2018 Inferno TRD Offroad Manual
    Sorry in advance, this question is specifically about our 5th gen 4runner, but I am also a 3rd gen Tacoma owner. Plus this forum is way better! This question is pretty broad and not 4runner specific anyway.
    Background: our 4runner has left my wife stranded twice at the gym early in the morning. We park it in the garage at night and the gym is about 5 minutes away. Starts fine leaving the house but won't start leaving the gym approx. 1 hour later. Starter makes a bunch of fast clicking noises. She has gotten somebody to jump her each time and it starts right up. Has started perfectly every other time during the day. Temps in the morning at the gym have been mid 50's. Temps in the daytime have been mid 80's.
    I have measured the battery multiple times with multimeter and gotten anywhere from 12.4 to 12.6 volts when vehicle is off. When running, 14 volts. Given that it has started right up both times when being jumped my intuition was the battery is going bad (it is 2 years old Duralast Gold) Took it to Autozone and they tested it and said battery is fine. Their tester said its actually the starter.
    My question is how do the battery testers at Autozone work? I'm talking about when he hooked it up to my battery, told me to start the vehicle, and the tester did its test, how does it know that the starter is the problem? Is it just process of elimination (i.e. it knows that battery isn't the problem, alternator isn't the problem, so must be starter)? Or is it more detailed than that? The guy wasn't real knowledgeable anyway and couldn't offer much more help. He had to ask if my vehicle was gas or diesel. Should I put much faith in his test?
    We agreed that my wife will drive my truck tomorrow. Glad she knows how to drive a manual!
  2. Sep 30, 2024 at 5:54 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    remove the cables, clean the terminals and make sure the cables are tight. im betting the issue is a true connection to the battery
    brian2sun, SR-71A, AZ Pete and 4 others like this.
  3. Sep 30, 2024 at 6:14 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    The auto parts stores do a load test which a standard home voltage meter cannot do. A load test tells you if you have one (or more) shorted out plates due to crap settling out in the bottom of the battery. You can always try swapping it out with another known good battery if you have one to see what happens. But I concur, clean the terminals!
  4. Sep 30, 2024 at 6:15 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    What he said. Especially because I've experienced this on my 4runner recently. The truck would start fine, but the radio would reboot and some other electrical gremlins. Turns out the battery terminal wasn't quite tight enough.
    But also, a bad cell in the battery won't be apparent to some of the battery testers. I've even had the one at Interstate say the battery was bad, but down the road it turned out it wasn't. There was a micro-drain on the battery that would only kill it over the long-term. It requires a hard load on the battery to make it obvious. I have an old tester that has ceramic heat sinks in the back and gets pretty hot while doing the load test. I doubt this is your issue, but just food for thought.
    jacobb81[OP] likes this.
  5. Sep 30, 2024 at 11:17 AM
    jacobb81
    Picked up a battery terminal and post brush and a can or cleaner/protectant at lunch today. Hope this fixes the problem!
  6. Sep 30, 2024 at 11:22 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I do a poor-man's load test which is to prop the multimeter up on the windshield so that I can read the volt drop when starting.
    12.5 volts is healthy enough for a resting battery. It should not drop below 10.5 when cranking.
    I agree with the peanut gallery. make sure the terminals are getting good contact.
    Taco Egghead, AZ Pete and shakerhood like this.
  7. Sep 30, 2024 at 11:27 AM
    Clearwater Bill
    Billy
    Largo Florida
    This ^^^^^
    If terminals are clean and tight, and you still have problems, I'll guess you drop to about 9v when cranking.
    SR-71A and jacobb81[OP] like this.
  8. Sep 30, 2024 at 11:34 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Yes, they're SUPPOSED to load test it. Depends on the person though. My friend just dealt with this and I asked her what the idle and load numbers were. She gave me one number. I asked which one, she didn't know..so I explained the process and she said they never asked her to turn stuff on. Told her to try another place and what to do.
    Taco Egghead likes this.
  9. Sep 30, 2024 at 11:37 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I do that too.
  10. Sep 30, 2024 at 11:37 AM
    auskip07
    Skip
    Atlanta, Ga
    My autozone employs lazy workers. After waiting 10 minutes after purchasing a battery, i told them to give me the tools
    Taco Egghead, BMH and shakerhood like this.
  11. Sep 30, 2024 at 11:56 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Buy a NOCO GB40 for every vehicle in the household ... even adult children living on their own. It will jumpstart when no one else can be found to help.
  12. Sep 30, 2024 at 12:11 PM
    shakerhood
    Southern Ohio
    I was watching a video on YouTube where they were fixing an old truck, head to AutoZone and an attractive women was heading to the counter. The employee sprinted from the back of the store, comment section was hilarious as everyone said l have never had an AutoZone employee run to the counter, lol.
    davidstacoma and STEELeR43 like this.
  13. Sep 30, 2024 at 12:12 PM
    auskip07
    Skip
    Atlanta, Ga
    There it is, im just an ugly white guy. I need to be pretty to get better service.
  14. Sep 30, 2024 at 12:36 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    My wife’s Dodge Durango did this last year, replaced the battery didn’t help, checked terminals by the connections, no issue. The culprit was a cracked positive terminal connector between the post and cable. Found it by just grabbing, putting tension on the cable, a slight wiggle and it would start right up. Might be worth checking.
    ABA180 likes this.
  15. Sep 30, 2024 at 12:38 PM
    RichochetRabbit
    Battery cables are often corroded (especially under the insulation) or cracked.
    I-Give-Up and BMH like this.
  16. Sep 30, 2024 at 12:42 PM
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    jacobb81[OP] and auskip07 like this.
  17. Sep 30, 2024 at 2:44 PM
    jacobb81
    I did try this over the weekend but I can't remember what number it dropped to. No red flags that I remember but I think I was looking for 8 or 9 V. Could very well of been around the 10.5 you mention and I thought it was ok. Will try again after I clean it all up and make sure everything is tight.
  18. Sep 30, 2024 at 2:45 PM
    jacobb81
    I've seen portable jump starters but didn't realize they came that small. Seems like a worthwhile investment that won't take up much space in the vehicle.
  19. Sep 30, 2024 at 2:52 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    They're worth owning. I keep jump packs in every vehicle, including the Miata.
    I've never used it on my own car, but I have helped strangers with it. And that's where it's vital. In the past I've had eager-to-helpers grab jumper cables out of my hand despite having no clue what to do with them. And sorry bud, but I'm not risking my highly voltage-sensitive car to your well-meaning but clumsy sparking. That's what I love about them. Self rescue if needed, and no risk to my equipment when I rescue others.
  20. Sep 30, 2024 at 2:59 PM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Do what auship07 said and I bet you'll figure out that you were wasting your time with the other testing.
